Compile errors for oceanFFT
I just tried to compile the oceanFFT sample app, and got the error messages shown below. I flashed JetPack 3 last night, from a laptop running Ubuntu 16.04. Suggestions?
nvidia@tegra-ubuntu:/usr/local/cuda-8.0/samples/5_Simulations/oceanFFT$ sudo make
[sudo] password for nvidia:
/usr/local/cuda-8.0/bin/nvcc -ccbin g++ -I…/…/common/inc -m64 -gencode arch=compute_53,code=sm_53 -gencode arch=compute_60,code=sm_60 -gencode arch=compute_62,code=sm_62 -gencode arch=compute_62,code=compute_62 -o oceanFFT.o -c oceanFFT.cpp
oceanFFT.cpp: In function ‘void display()’:
oceanFFT.cpp:522:5: error: reference to ‘glClientActiveTexture’ is ambiguous
glClientActiveTexture(GL_TEXTURE0);
In file included from …/…/common/inc/helper_gl.h:23:0,
from oceanFFT.cpp:37:
/usr/include/GL/gl.h:1825:23: note: candidates are: void glClientActiveTexture(GLenum)
GLAPI void GLAPIENTRY glClientActiveTexture( GLenum texture );
In file included from oceanFFT.cpp:37:0:
…/…/common/inc/helper_gl.h:107:17: note: void (* __HelperGL::glClientActiveTexture)(GLenum)
USE_GL_FUNC(glClientActiveTexture, PFNGLACTIVETEXTUREPROC);
…/…/common/inc/helper_gl.h:45:44: note: in definition of macro ‘USE_GL_FUNC’
#define USE_GL_FUNC(name, proto) proto name = (proto) glXGetProcAddress ((const GLubyte )#name)
oceanFFT.cpp:527:5: error: reference to ‘glClientActiveTexture’ is ambiguous
glClientActiveTexture(GL_TEXTURE1);
oceanFFT.cpp:579:5: error: reference to ‘glClientActiveTexture’ is ambiguous
oceanFFT.cpp:581:5: error: reference to ‘glClientActiveTexture’ is ambiguous
#define USE_GL_FUNC(name, proto) proto name = (proto) glXGetProcAddress ((const GLubyte *)#name)
Makefile:270: recipe for target ‘oceanFFT.o’ failed
make: *** [oceanFFT.o] Error 1
Oops. Should have just tried Google first–answered at https://devtalk.nvidia.com/default/topic/999381/jetpack-compiling-oceanfft-on-tx2/
That solution worked for me.
