but I found this warning: “configure: WARNING: *** Couldn’t figure out how to link C and Fortran; switching to --disable-fortran”. Therefore, any suggestions?
The compiled fftw library will be used by a code writen in F90. I wonder if I should compile fftw with F77=“pgf90”?
In order to improve the performace, can you tell me if the CFLAG and FFLAG is sufficient (the processor in my cluster is opteron x86_64)?
Replace the GNU “-m64” flag with the PGI equivlent “-tp k8-64”.
You could. However unless the code is actually written in F90, it is prefered to use a F77 compiler. This will make your library more portable and compatable with other compilers.
FFTW is a highly optimized library, so adding additional compiler optimization may only give you marginal gains. Personally, I would favor precision at the cost of some performance and use “-fastsse -Kieee -tp k8-64”. However, it’s up to you if “-Kieee” is needed in your situation.
The code I am compiling using PGI is VASP, and it can be accelerated by the fftw code. The VASP code is indeed writen by F90, but I am not sure if “-Kieee” is needed.
Now, I have tried configure:
./configure CC=“pgcc” CFLAGS=" -fast -tp k8-64" F77=“pgf90” FFLAG=“-fast -tp k8-64”
However, the error also occurs:
checking for Fortran 77 libraries… -lm’ -L/home/vasp/opt/pgi7/linux86-64/7.0-4/lib -L/usr/lib64 -L/usr/lib/gcc/x86_64-redhat-linux/3.4.6 -lm -lpgf90 -lpgf90_rpm1 -lpgf902 -lpgf90rtl -lpgftnrtl -lnspgc -lpgc -lrt -lpthread
checking for dummy main to link with Fortran 77 libraries… unknown
configure: WARNING: *** Couldn’t figure out how to link C and Fortran; switching to --disable-fortran.
Even if your end application (VASP) is F90, it’s prefered that FFTW be compiled with pgf77. This will make your library more portable. F90 code can use F77 libraries.
I just tried your configure line using FFTW 3.1.2 and it worked fine. Try looking through the resulting config.log to determine what the actual error is. Hopefully then we can determine a solution.
I have also tried fftw3.1.2, and it works fine using my configure.
In my config.log file, I only find the errors: “PGC/x86-64 Linux 7.0-4: compilation completed with severe errors” and “PGC-S-0035-Syntax error: Recovery attempted by replacing identifier me by ‘;’ (conftest.c: 2)”. Can I send my config.log file to you?
I was able to find a copy of FFTW 3.0.1 and reporduce the error. It looks like the configure file is failing to parse pgf77 verbose output correctly. As a work-around, comment out line 14873 from configure.
Change:
if test $ac_cv_lib_m_sin = yes; then
cat >>confdefs.h <<_ACEOF
#define HAVE_LIBM 1
_ACEOF
LIBS="-lm $LIBS"
fi
to
#define HAVE_LIBM 1
_ACEOF
# LIBS="-lm $LIBS"
fi
