Is there any way to compile the entire deepstream (newest) from source, without using the tar binaries at all ?
Thanks for the help !
Hi dannykario,
The DeepStream SDK source files are not opened, you can only use the tar binaries.
May I know why you need to build it from source? Any specific requirement?
I moved to JP 4.4 and it seems ds is not supported (i think its the TRT7 version?).
So , I was hoping to compile it and see if I overcome issue in the transfer. I only need very small part of the SDK …
Any ideas ?
Hi dannykario,
Yes, that is cased by new TRT verson, we will be releasing a new DeepStream SDK to work with JP 4.4 DP soon. Please stay tuned.
The DeepStream SDK 5.0 preview version have been released, it can work with JP 4.4 DP. Please get it a try. Thanks
