compile into .so file link error
hi
I want to compile the yolo code into .so file,then use the .so in my application in TX1
first, I can compile the yolo source code successfully in the tx1.
second, I add the header file and source file of .so into the yolo source. and modify the Makefile. the process of compiling .o files is smoothly,but while linking .o to generate .so file, appear some error:
/usr/bin/ld: obj/cuda.o: relocation R_AARCH64_ADR_PREL_PG_HI21 against external symbol ‘__stack_chk_guard@@GLIBC_2.17’ can not be when making a shared object; recompile with -fPIC
/usr/bin/ld:obj/cudo.o(.text_0x88):unresolvable R_AARCH64_ADR_PREL_PG_HI21 relocation against symbol ‘__stack_chk_guard@@GLIBC_2.17
/usr/bin/ld: final link failed: Bad value
collect2:error:;d retruned 1 exit status.
cuda.o is generated by cuda.c in the YOLO source code,not the file created by myself.
I think the error is relevant with cross platform compiling.
Thanks for your question. Could you help to provide more information?
  1. Which source code did you use?
  2. Did you compile .so on device or host? And you want the .so to run on tx1, right?
By the way, I just googled your error message and found a similar issue.
They fixed by changing the path order of the linked libraries. Could you also give it a try?
https://forum.qt.io/topic/75858
hi AstaLLL,
thanks for your reply.
I compile .so on the tx1 drectly.
source code of cuda.c and cuda.h
#ifndef CUDA_H
#define CUDA_H
extern int gpu_index;
#ifdef GPU
#define BLOCK 512
#include "cuda_runtime.h"
#include "curand.h"
#include "cublas_v2.h"
#ifdef CUDNN
#include "cudnn.h"
#endif
void check_error(cudaError_t status);
cublasHandle_t blas_handle();
float *cuda_make_array(float *x, size_t n);
int *cuda_make_int_array(size_t n);
void cuda_push_array(float *x_gpu, float *x, size_t n);
void cuda_pull_array(float *x_gpu, float *x, size_t n);
void cuda_set_device(int n);
void cuda_free(float *x_gpu);
void cuda_random(float *x_gpu, size_t n);
float cuda_compare(float *x_gpu, float *x, size_t n, char *s);
dim3 cuda_gridsize(size_t n);
float cuda_mag_array(float *x_gpu, size_t n);
#ifdef CUDNN
cudnnHandle_t cudnn_handle();
#endif
#endif
#endif
int gpu_index = 0;
#ifdef GPU
#include "cuda.h"
#include "utils.h"
#include "blas.h"
#include "assert.h"
#include <stdlib.h>
#include <time.h>
    gpu_index = n;
    cudaError_t status = cudaSetDevice(n);
    check_error(status);
int cuda_get_device()
    int n = 0;
    cudaError_t status = cudaGetDevice(&n);
    return n;
    //cudaDeviceSynchronize();
    cudaError_t status2 = cudaGetLastError();
    if (status != cudaSuccess)
        const char *s = cudaGetErrorString(status);
        char buffer[256];
        printf("CUDA Error: %s\n", s);
        assert(0);
        snprintf(buffer, 256, "CUDA Error: %s", s);
        error(buffer);
    if (status2 != cudaSuccess)
        char buffer[256];
        printf("CUDA Error Prev: %s\n", s);
        assert(0);
        snprintf(buffer, 256, "CUDA Error Prev: %s", s);
        error(buffer);
dim3 cuda_gridsize(size_t n){
    size_t k = (n-1) / BLOCK + 1;
    size_t x = k;
    size_t y = 1;
    if(x > 65535){
        x = ceil(sqrt(k));
        y = (n-1)/(x*BLOCK) + 1;
    dim3 d = {x, y, 1};
    //printf("%ld %ld %ld %ld\n", n, x, y, x*y*BLOCK);
    return d;
#ifdef CUDNN
    static int init[16] = {0};
    static cudnnHandle_t handle[16];
    int i = cuda_get_device();
    if(!init[i]) {
        cudnnCreate(&handle[i]);
        init[i] = 1;
    return handle[i];
#endif
    static cublasHandle_t handle[16];
    if(!init[i]) {
        cublasCreate(&handle[i]);
        init[i] = 1;
    return handle[i];
    float *x_gpu;
    size_t size = sizeof(float)*n;
    cudaError_t status = cudaMalloc((void **)&x_gpu, size);
    if(x){
        status = cudaMemcpy(x_gpu, x, size, cudaMemcpyHostToDevice);
    if(!x_gpu) error("Cuda malloc failed\n");
    return x_gpu;
    static curandGenerator_t gen[16];
    if(!init[i]){
        curandCreateGenerator(&gen[i], CURAND_RNG_PSEUDO_DEFAULT);
        curandSetPseudoRandomGeneratorSeed(gen[i], time(0));
        init[i] = 1;
    curandGenerateUniform(gen[i], x_gpu, n);
    check_error(cudaPeekAtLastError());
    float *tmp = calloc(n, sizeof(float));
    cuda_pull_array(x_gpu, tmp, n);
    //int i;
    //for(i = 0; i < n; ++i) printf("%f %f\n", tmp[i], x[i]);
    axpy_cpu(n, -1, x, 1, tmp, 1);
    float err = dot_cpu(n, tmp, 1, tmp, 1);
    printf("Error %s: %f\n", s, sqrt(err/n));
    free(tmp);
    return err;
    int *x_gpu;
    size_t size = sizeof(int)*n;
    return x_gpu;
    cudaError_t status = cudaFree(x_gpu);
    cudaError_t status = cudaMemcpy(x_gpu, x, size, cudaMemcpyHostToDevice);
    cudaError_t status = cudaMemcpy(x, x_gpu, size, cudaMemcpyDeviceToHost);
    float *temp = calloc(n, sizeof(float));
    cuda_pull_array(x_gpu, temp, n);
    float m = mag_array(temp, n);
    free(temp);
    return m;
#endif
the cuda.c and cuda.h call the CUDA API
can you give me some suggestion?
I can compile a .so based on your source code without error.
Here is my Makefile, I compiled directly on tx1.
all:
        nvcc -arch=sm_53 -Xcompiler '-fPIC' -dc cuda.c
        nvcc -arch=sm_53 -Xcompiler '-fPIC' -dlink cuda.o -o raw.o
        g++ -shared -o test.so raw.o
