Compile Issues
I am crashing out on a compile with the following error:
nvcc fatal : Value ‘sm_10’ is not defined for option ‘gpu-architecture’
Why is this happening?
As I recall support for sm_10 was deprecated/removed from CUDA 6.
ubuntu@tegra-ubuntu:~/$ nvcc --help
--gpu-architecture <gpu architecture name>
Allowed values for this option:  'compute_20','compute_30','compute_32',
        'compute_35','compute_50','sm_20','sm_21','sm_30','sm_32','sm_35',
        'sm_50'.
Check the makefile and remove sm_10.
I edited the Makefile and changed it to sm_20 and it compiled!
Dear all,
I found this thread, because I have the same problem as Pyrex.
However I do not know where to find the Makefile, where the corresponding line can be commented out or changed to omit the -arch=sm_13 definition.
In the following the full error message:
[Kraut@Wzmbx001 build44]$ make
Scanning dependencies of target log4lama
[ 0%] Building CXX object logging/CMakeFiles/log4lama.dir/GenLogger.cpp.o
[ 1%] Building CXX object logging/CMakeFiles/log4lama.dir/GenLoggerCreator.cpp.o
[ 1%] Building CXX object logging/CMakeFiles/log4lama.dir/Level.cpp.o
[ 2%] Building CXX object logging/CMakeFiles/log4lama.dir/Logger.cpp.o
[ 2%] Building CXX object logging/CMakeFiles/log4lama.dir/LoggerProvider.cpp.o
[ 3%] Building CXX object logging/CMakeFiles/log4lama.dir/SourceLocation.cpp.o
Linking CXX shared library liblog4lama.so
[ 3%] Built target log4lama
[ 3%] Building NVCC (Device) object lama/cuda/CMakeFiles/cuda_compile.dir//./cuda_compile_generated_CUDACOOUtils.cu.o
nvcc fatal : Value ‘sm_13’ is not defined for option ‘gpu-architecture’
CMake Error at cuda_compile_generated_CUDACOOUtils.cu.o.cmake:202 (message):
Error generating
/opt/OpenFOAM/lama/build44/lama/cuda/CMakeFiles/cuda_compile.dir//./cuda_compile_generated_CUDACOOUtils.cu.o
make[2]: *** [lama/cuda/CMakeFiles/cuda_compile.dir/./cuda_compile_generated_CUDACOOUtils.cu.o] Error 1
make[1]: *** [lama/cuda/CMakeFiles/amacuda.dir/all] Error 2
make: *** [all] Error 2
Thanks a log for any hints. I am stuck on this right now.
All help is highly
appreciated!
Best,
KingKraut
Hi KingKraut,
The makefiles should be existing within the each sample code directory you wish to build.
Hi kayccc,
thanks a lot for the hint.
I found the respective lines in file lama/Cmake/Modules/SetNVCCFlags.cmake.
There the value 13 needs to be deleted since it is not supported by newer CUDA versions.
