Hej,
is there a quick fix to compile MLNX_OFED_LINUX-5.1-2.3.7.1-rhel8.2-x86_64 against Kernel 5.8.12?
Don’t get fooled by the Kernel name, it is CentOS 8.2 with a Fedora Kernel :)
CC [M] /tmp/MLNX_OFED_LINUX-5.1-2.3.7.1-5.8.12-100.fc31.x86_64/mlnx_iso.2710/OFED_topdir/BUILD/mlnx-ofa_kernel-5.1/obj/default/drivers/net/ethernet/mellanox/mlx5/core/en_sysfs.o
/tmp/MLNX_OFED_LINUX-5.1-2.3.7.1-5.8.12-100.fc31.x86_64/mlnx_iso.2710/OFED_topdir/BUILD/mlnx-ofa_kernel-5.1/obj/default/drivers/infiniband/core/umem_odp.c: In function ‘ib_umem_odp_map_dma_pages’:
/tmp/MLNX_OFED_LINUX-5.1-2.3.7.1-5.8.12-100.fc31.x86_64/mlnx_iso.2710/OFED_topdir/BUILD/mlnx-ofa_kernel-5.1/obj/default/drivers/infiniband/core/umem_odp.c:1132:25: error: ‘struct mm_struct’ has no member
down_read(&owning_mm->mmap_sem);
mmap_base
/tmp/MLNX_OFED_LINUX-5.1-2.3.7.1-5.8.12-100.fc31.x86_64/mlnx_iso.2710/OFED_topdir/BUILD/mlnx-ofa_kernel-5.1/obj/default/drivers/infiniband/core/umem_odp.c:1163:23: error: ‘struct mm_struct’ has no member
up_read(&owning_mm->mmap_sem);
mmap_base
/tmp/MLNX_OFED_LINUX-5.1-2.3.7.1-5.8.12-100.fc31.x86_64/mlnx_iso.2710/OFED_topdir/BUILD/mlnx-ofa_kernel-5.1/obj/default/drivers/infiniband/core/umem_odp.c: At top level:
cc1: warning: unrecognized command line option ‘-Wno-address-of-packed-member’
make[4]: *** [scripts/Makefile.build:281: /tmp/MLNX_OFED_LINUX-5.1-2.3.7.1-5.8.12-100.fc31.x86_64/mlnx_iso.2710/OFED_topdir/BUILD/mlnx-ofa_kernel-5.1/obj/default/drivers/infiniband/core/umem_odp.o] Error
make[4]: *** Waiting for unfinished jobs…
Greetings,
Bjoern
mlnx-ofa_kernel-5.1.rpmbuild.log (424 KB)
