Hello ,
I am having some c files and because I want to create another cu file ,I am trying to make them run in nsight.
At the moment I build the project (CUDA project , nvcc) the c files are full of errors.
I have also some header files , in which I added:
#ifdef __cplusplus
#ifndef __CDT_PARSER__
extern "C" {
#endif
#endif
and some errors were removed.
But I am still having errors like:
incompatible types when assigning to type ‘mycplx’ from type ‘double’
A[ I * Cols + J ] = ( cos( ( PI * m * ( y - y_0 ) ) / inLy ) );
where mycplx is defined in a header:
typedef fftwf_complex mycplx;
When I was running code in c everything was ok ( using -std=c99) .
I haven’t found a way to declare nvcc to use c99 .
