nvidia-container-runtime$ make
make -C /home/nvidia/Apollo/apollo_new/nvidia-container-runtime/base ubuntu18.04
make[1]: Entering directory ‘/home/nvidia/Apollo/apollo_new/nvidia-container-runtime/base’
docker build --build-arg VERSION_ID=“18.04”
–build-arg GOLANG_VERSION=“1.10.3”
-t “nvidia/base/ubuntu:18.04” -f Dockerfile.ubuntu .
Sending build context to Docker daemon 9.216kB
Step 1/7 : ARG VERSION_ID
Step 2/7 : FROM ubuntu:{VERSION_ID}
---> 9f020c638543
Step 3/7 : RUN apt-get update && apt-get install -y --no-install-recommends wget ca-certificates git build-essential dh-make fakeroot devscripts lsb-release && rm -rf /var/lib/apt/lists/*
---> Using cache
---> a9e0d8165f5a
Step 4/7 : ARG GOLANG_VERSION=0.0.0
---> Using cache
---> 3310366261ef
Step 5/7 : RUN set -eux; arch="(uname -m)"; case "{arch##*-}" in x86_64 | amd64) ARCH='amd64' ;; ppc64el | ppc64le) ARCH='ppc64le' ;; *) echo "unsupported architecture" ; exit 1 ;; esac; wget -nv -O - https://storage.googleapis.com/golang/go{GOLANG_VERSION}.linux-${ARCH}.tar.gz | tar -C /usr/local -xz
—> Running in 542f1cc5aa3c
- uname -m
unsupported architecture - arch=aarch64
- echo unsupported architecture
- exit 1
The command ‘/bin/sh -c set -eux; arch="(uname -m)"; case "{arch##*-}" in x86_64 | amd64) ARCH=‘amd64’ ;; ppc64el | ppc64le) ARCH=‘ppc64le’ ;; *) echo “unsupported architecture” ; exit 1 ;; esac; wget -nv -O - https://storage.googleapis.com/golang/go${GOLANG_VERSION}.linux-${ARCH}.tar.gz | tar -C /usr/local -xz’ returned a non-zero code: 1
Makefile:13: recipe for target ‘ubuntu18.04’ failed
make[1]: *** [ubuntu18.04] Error 1
make[1]: Leaving directory ‘/home/nvidia/Apollo/apollo_new/nvidia-container-runtime/base’
Makefile:25: recipe for target ‘base-ubuntu18.04’ failed
make: *** -ubuntu18.04] Error 2
