How to add gradle subprojects to the gradle build which are located in subfolders near nsight_tegra_build_overrides?
Internet says to declare subprojects in settings.gradle as
include 'OffersSDK'
project(':OffersSDK').projectDir = new File('F:/Work/Svn/demos/pm2/vsandroid/gradle/deps/OffersSDK')
and then use it in nsight_tegra_build_overrides.gradle
dependencies
compile project(':OffersSDK')
But that does not seem to work as I get :
Compiling settings file ‘F:\Work\Svn\demos\pm2\vsandroid\Tegra-Android\Release\build\settings.gradle’ using BuildScriptTransformer.
Settings evaluated using empty settings script.
From output console if I copy settings.gradle to \Tegra-Android\Release\build\ manually, otherwise it is not even compiled by gradle and i`m not sure the gradle build uses settings even then. Moreover it seems that gradle script is executed from temp dir F:\Work\Svn\demos\pm2\vsandroid\Tegra-Android\Release\build and compile project method looks for project in the temp dir.
Is there any solution to this?
