Compiler Bug: Assertion failure at line 1923 of ../../be/cg/cgemit.cxx incorrect reg
The compiler gave me some troubles, so I reduced it to a small repro problem:
__global__ void bug_kernel(long* vs) {
	long mask = 1;
	long v = threadIdx.x ? mask : 0;
	#pragma unroll
	for(int i = 1; i < 64; i++)
		v ^= mask << i;
	vs[threadIdx.x] = v;
For which the compiler outputs the error:
### Assertion failure at line 1923 of ../../be/cg/cgemit.cxx:
### Compiler Error in file /tmp/tmpxft_000058b4_00000000-7_bug.cpp3.i during Assembly phase:
### incorrect register class for operand 0
nvopencc INTERNAL ERROR: /usr/local/cuda/open64/lib//be returned non-zero status 1
Using CUDA 4.0 Production Release.
	long mask = 1;
	#pragma unroll
		v ^= mask << i;
This kind of error message indicates an internal compiler bug. Since you already have a repro case in hand, please file a bug against the compiler. The compiler team may be able to suggest a workaround once they determine the underlying cause. Sorry for the inconvenience, and thank you for your help.
