Hello
The fortran source below leads to bad code under compiler optimisation.
Version:
pgf90 7.1-0e 64-bit target on x86-64 Linux
Flags:
-fast -Mvect=levels:3 -KPIC -Kieee -Mcache_align -Mreentrant -Miomutex -Mlarge_arrays -c -gopt -Mkeepasm -Manno
Reducing optimisation to
-Mvect=levels:2
avoids the bug.
SUBROUTINE G13DSZN(LDR,K,K2,M,N,R,P,Q,PARHLD,NPAR,R0,TEMP,WORK,
* SUM,IDF,SIGLEV,IFAILA,IFAULT)
C MARK 13 RELEASE. NAG COPYRIGHT 1988.
C MARK 15 REVISED. IER-926 (APR 1991).
C MARK 16 REVISED. IER-1122 (JUL 1993).
C
C This subroutine calculates the portmanteau statistic and its'
C significance level
C
C .. Scalar Arguments ..
DOUBLE PRECISION SIGLEV, SUM
INTEGER IDF, IFAILA, IFAULT, K, K2, LDR, M, N, NPAR, P, Q
C .. Array Arguments ..
DOUBLE PRECISION R(LDR,LDR,M), R0(K,K), TEMP(K2+1,K2), WORK(K2)
LOGICAL PARHLD(NPAR)
C .. Local Scalars ..
INTEGER I, I2, IFAIL, J, J2, L
CHARACTER*200 ERRBUF
C .. External Functions ..
DOUBLE PRECISION G01ECFN
EXTERNAL G01ECFN
C .. External Subroutines ..
EXTERNAL F01ADFN
C .. Intrinsic Functions ..
INTRINSIC DBLE
C .. Intents ..
INTENT(IN) :: LDR, K, K2, M, N, R, P, Q, PARHLD, NPAR, IFAULT
C .. Executable Statements ..
CONTINUE
PRINT '(2I6)', K, K2
IFAILA = 0
IF (IFAULT.EQ.3) GO TO 280
C
C first copy R0 onto TEMP
C
DO 40 J = 1, K
DO 20 I = 1, K
TEMP(I,J) = R0(I,J)
20 CONTINUE
40 CONTINUE
C
C invert RO
C
IFAIL = 1
CALL F01ADFN(K,TEMP,K2+1,ERRBUF,IFAIL)
IF (IFAIL.GT.0) THEN
IFAILA = 3
GO TO 280
END IF
C set R0 = R0
C
DO 80 I = 1, K
DO 60 J = 1, I
R0(I,J) = TEMP(I+1,J)
R0(J,I) = R0(I,J)
60 CONTINUE
80 CONTINUE
C -1 -1
C compute R0 ** R0 where ** denotes kronecker product
C
DO 160 J = 1, K
DO 140 I = 1, K
SUM = R0(I,J)
DO 120 J2 = 1, K
DO 100 I2 = 1, K
TEMP((I-1)*K+I2,(J-1)*K+J2) = SUM*R0(I2,J2)
100 CONTINUE
120 CONTINUE
140 CONTINUE
160 CONTINUE
C
C calculate Li-McLeod statistic
C
SUM = 0.0D0
C
DO 260 L = 1, M
C
C copy vec(R(L)') onto WORK
C
C Note that these R(L)'s are the transpose of those defined in
C Li and McLeod's paper
C
DO 200 I = 1, K
DO 180 J = 1, K
WORK((I-1)*K+J) = R(J,I,L)
180 CONTINUE
200 CONTINUE
C
DO 240 J = 1, K2
DO 220 I = 1, K2
SUM = SUM + WORK(I)*TEMP(I,J)*WORK(J)
220 CONTINUE
240 CONTINUE
C
260 CONTINUE
C
SUM = SUM*DBLE(N)
C
C modify Li-McLeod statistic
C
SUM = SUM + (DBLE(K2*M*(M+1))/DBLE(2*N))
C
C calculate degrees of freedom
C
280 IDF = K2*(M-P-Q)
DO 300 I = 1, NPAR
IF (PARHLD(I)) IDF = IDF + 1
300 CONTINUE
IF (IFAILA.EQ.3 .OR. IFAULT.EQ.3) RETURN
IFAIL = 1
SIGLEV = G01ECFN('U',SUM,DBLE(IDF),ERRBUF,IFAIL)
RETURN
C
END
