Compiler bug under pgf90 5.1-6
My short code fails under version 5.1-6 when I use the -fastsse compiler option (actually, just -Munroll -scalarsse seems to cause the behavior), but the code works fine using any other compiler options I tried and under version 5.2-4 and version 6.2-5. So I think it’s a compiler bug but I just want to be sure. Is there a way to verify this?
The code looks like this:
      implicit none
      real*8  :: cof(10,2)
      real*8  :: t1,t2,t3,t4,ti,ts,tl,tp,hs,css,ss
      continue
      open(13,FILE='array')
      read(13,*)cof(:,1)
      close(13)
      tp  = 2.5d4
      t1 = tp
      t2 = t1*t1
      t3 = t2*t1
      t4 = t3*t1
      ti = 1.0d0/t1
      ts = ti*ti
      tl = log(t1)
      hs  = cof(3,1)        + cof(2,1)*ti*tl   &
          - cof(1,1)*ts     + 0.5*cof(4,1)*t1  &
          + (1.0d0/3.0d0)*cof(5,1)*t2 + 0.25*cof(6,1)*t3 &
          + 0.2*cof(7,1)*t4 + cof(9,1)*ti - 1.0d0
      css = cof(1,1)*ts + cof(2,1)*ti &
          + cof(3,1)    + cof(4,1)*t1 + cof(5,1)*t2 &
          + cof(6,1)*t3 + cof(7,1)*t4
      ss  = cof(3,1)*tl     - cof(2,1)*ti - 0.5*cof(1,1)*ts &
          + cof(4,1)*t1     + 0.5*cof(5,1)*t2 &
          + (1.0d0/3.0d0)*cof(6,1)*t3 + 0.25*cof(7,1)*t4 + cof(10,1)
      cof(3,2)  = css
      cof(9,2)  = (hs + 1.0d0 - cof(3,2))*tp
      cof(10,2) =  ss - cof(3,2)*log(tp)
      write(*,*)cof(:,:)
… and the data file that is needed looks like this
 -9.95126508D+08  6.45888726D+05 -1.67589470D+02  2.31993336D-02 -1.72108091D-06
  6.53193846D-11 -9.74014773D-16  0.00000000D+00 -5.07830034D+06  1.46529848D+03
When the code works, cof(10,2) is about 19, when it fails it is 6.7e+20.
Thanks,
David
Hi David,
It looks like a bug to me as well but I don’t see anything similar in our 5.1 problem reports. It might have been found internally. In any case, it does appear to have been fixed and is limited to the 32-bit SSE code generator at opt level 2 (i.e. “-O2 -Mscalarsse”, or “-fastsse”).
  • Mat
