compiler error: count
Hi
When I want to compile a code using “pgf90” the compiler gives me the following error message.
Code looks like:
do i=1,2
   do j=1,10
      if (count(isnand(Array1(1:5,Array2(i,1,j)))).gt.0) then
      end if
   end do
end do
PGF90-S-0074-Illegal number or type of arguments to count - keyword argument mask
PGF90-S-0038-Symbol, isnand, has not been explicitly declared
I read that I have to use “isnsnd” for double precision numbers. Correct?
What can I do?
Thank you!
Hi elephant,
You need to declare “isnand” since it’s an external function.
Though, I would suggest using the F2003 “ieee_is_nan” routine instead since it’s a standard Fortran elemental function rather then an extension or external routine. For example:
! need to use the ieee_arithmetic module
use ieee_arithmetic
do i=1,2
   do j=1,10
      if (count(ieee_is_nan(Array1(1:5,Array2(i,1,j)))).gt.0) then
      end if
   end do
end do
Hope this helps,
Mat
Perfect! It worked!
Thnak you
