Compiler error: Predicate variable must be in register state space
Hi all,
whenever I am trying to compile a kernel that uses code similar to
__local bool pred;
if (pred) {}
else {}
I get the following error:
Build Log:
ptxas application ptx input, line 17; error   : Predicate variable 'shr_1_early' must be in register state space
ptxas fatal   : Ptx assembly aborted due to errors
error   : Ptx compilation failed: gpu='sm_13', device code='anonymous_jit_identity'
: Retrieving binary for 'anonymous_jit_identity', for gpu='sm_13', usage mode=' --maxrregcount 32'
: Considering profile 'compute_10' for gpu='sm_13' in 'anonymous_jit_identity'
: Control flags for 'anonymous_jit_identity' disable search path
: Ptx binary found for 'anonymous_jit_identity', architecture='compute_10'
: Ptx compilation for 'anonymous_jit_identity', for gpu='sm_13', ocg options=' --maxrregcount 32'
!!! Error # -45 (CL_INVALID_PROGRAM_EXECUTABLE) at line 141 , in file main.cpp !!!
Exiting...
Is my code not conforming to the OpenCL spec or is this a compiler bug?
Edit: I am using CUDA 3.0 final
Best,
Jens
Looks like a bug in the compiler. Just curious, why do you want to use ‘__local bool’? Do you mean ‘__private bool’ (which is compiled fine)?
Thanks. I was playing around with a __local bool as I am running into register pressure and I have a non-trivial condition in my kernel … it was mostly just an experiment, I guess it wouldn’t have been that helpful. However I was confused by the result :rolleyes:
