Compiler Error saying 'identifier "__builtin_ia32_serialize" is undefined' while running CUDA
-1
I am using GEC Library (GitHub - HareInWeed/gec: elliptic curve cryptography with GPU acceleration) to perform point operations on secp26k1. This project has the provision of using CUDA.
#include <gec/utils/macros.hpp>
#include <gec/bigint.hpp>
#include <gec/curve.hpp>
// nvcc i_hope.cu
using namespace gec::bigint::literal;
using Bigint256 = gec::bigint::ArrayBE<uint64_t, 4>;
GEC_DEF_GLOBAL(MOD, Bigint256,     // cardinality of finite field
    0xfffffffffffffffffffffffffffffffffffffffffffffffffffffffefffffc2f_int);
constexpr Bigint256::LimbT MOD_P = // -MOD^-1 mod 2^64
    0xd838091dd2253531ull;
GEC_DEF_GLOBAL(RR, Bigint256,      // 2^512 mod MOD
    0x01000007a2000e90a1_int);
GEC_DEF_GLOBAL(ONE_R, Bigint256,   // 2^256 mod MOD
    0x1000003d1_int);
using Field = GEC_BASE_FIELD(Bigint256, MOD, MOD_P, RR, ONE_R);
 const Field B(0x700001ab7_int);
__constant__ const Field d_B(0x700001ab7_int);
using Secp256k1   = GEC_CURVE_B(gec::curve::JacobianCurve, Field, B);
 const Secp256k1 Gen(
    Field(0x9981e643e9089f48979f48c033fd129c231e295329bc66dbd7362e5a487e2097_int),
    Field(0xcf3f851fd4a582d670b6b59aac19c1368dfc5d5d1f1dc64db15ea6d2d3dbabe2_int),
    Field(0x1000003d1_int)
__constant__ const Secp256k1 d_Gen(
__global__ void cuda_kernel()
    Secp256k1 p1;
    Secp256k1::mul(p1, 1, d_Gen);
    p1.print();
int main()
 cuda_kernel<<<1,1>>>();
 cudaDeviceSynchronize();
 return 0;
I am getting the below error
/usr/lib/gcc/x86_64-linux-gnu/11/include/serializeintrin.h(41): error: identifier "__builtin_ia32_serialize" is undefined
1 error detected in the compilation
CUDA Version
Copyright (c) 2005-2021 NVIDIA Corporation
Built on Thu_Nov_18_09:45:30_PST_2021
Cuda compilation tools, release 11.5, V11.5.119
Build cuda_11.5.r11.5/compiler.30672275_0
I am using Ubuntu 22.04
The Contents of serializeintrin.h located at /usr/lib/gcc/x86_64-linux-gnu/11/include/ is below.
#ifndef _X86GPRINTRIN_H_INCLUDED
# error "Never use <serializeintrin.h> directly; include <x86gprintrin.h> instead."
#endif
#ifndef _SERIALIZE_H_INCLUDED
#define _SERIALIZE_H_INCLUDED
#ifndef __SERIALIZE__
#pragma GCC push_options
#pragma GCC target("serialize")
#define __DISABLE_SERIALIZE__
#endif /* __SERIALIZE__ */
extern __inline void
__attribute__((__gnu_inline__, __always_inline__, __artificial__))
_serialize (void)
  __builtin_ia32_serialize ();
#ifdef __DISABLE_SERIALIZE__
#undef __DISABLE_SERIALIZE__
#pragma GCC pop_options
#endif /* __DISABLE_SERIALIZE__ */
#endif /* _SERIALIZE_H_INCLUDED.  */
gcc (Ubuntu 11.3.0-1ubuntu1~22.04.1) 11.3.0
Thanks for the response. I am the one who has asked that question on Stack Overflow also… GCC is up to date.
