I have a program that I compile a couple of different ways. It utilizes DO CONCURRENT loops and the stdpar flag. When I have DO CONCURRENT loops and data movement OpenACC pragmas and compile with “-stdpar=multicore”, I get the error below. If I remove the data movement pragmas, the code compiles fine. I compile two separate versions for my needs with “-stdpar=multicore” and “-stdpar=gpu” because I need dedicated versions for both the CPU and GPU. I leave the data movement pragmas in my CPU code so that I do not need to have multiple versions of my code.
nvfortran-Fatal-/opt/nvidia/hpc_sdk/Linux_x86_64/21.5/compilers/bin/tools/fort2 TERMINATED by signal 11
Arguments to /opt/nvidia/hpc_sdk/Linux_x86_64/21.5/compilers/bin/tools/fort2
/opt/nvidia/hpc_sdk/Linux_x86_64/21.5/compilers/bin/tools/fort2 /tmp/nvfortranjsUjBC50nOxH.ilm -fn diffuse_Y-ACC_Y-OMP_Y-DC-R/diffuse.f -opt 3 -terse 1 -inform warn -x 51 0x20 -x 119 0xa10000 -x 122 0x40 -x 123 0x1000 -x 127 4 -x 127 17 -x 19 0x400000 -x 28 0x40000 -x 120 0x10000000 -x 70 0x8000 -x 122 1 -x 125 0x20000 -quad -vect 56 -y 34 16 -x 34 0x8 -x 32 31457280 -y 19 8 -y 35 0 -x 42 0x30 -x 39 0x40 -x 39 0x80 -x 59 4 -x 129 2 -tp haswell -x 120 0x1000 -x 124 0x1400 -y 15 2 -x 57 0x3b0000 -x 58 0x48000000 -x 49 0x100 -astype 0 -x 121 1 -x 183 4 -x 121 0x800 -x 68 0x1 -x 8 0x40000000 -x 70 0x40000000 -x 56 0x10 -x 54 0x10 -x 249 110 -x 68 0x20 -x 70 0x40000000 -x 8 0x40000000 -x 164 0x800000 -x 85 0x2000 -x 85 0x4000 -x 34 0x40000000 -x 53 0x800000 -x 68 0x1 -x 39 4 -x 56 0x10 -x 26 0x10 -x 26 1 -x 56 0x4000 -x 124 1 -accel multicore -accel multicore -x 180 0x4000400 -x 121 0xc00 -x 186 0x80 -x 163 1 -x 186 0x80000 -x 180 0x400 -x 121 0xc00 -x 210 8 -x 180 0x4000400 -x 121 0xc00 -x 186 0x80 -x 163 1 -x 186 0x80000 -x 180 0x400 -x 121 0xc00 -x 240 0x1 -x 210 8 -y 163 0xc0000000 -x 189 0x10 -y 189 0x4000000 -x 9 1 -x 72 0x1 -x 136 0x11 -x 37 0x480000 -x 9 1 -x 72 0x1 -x 136 0x11 -x 37 0x480000 -x 0 0x1000000 -x 2 0x100000 -x 0 0x2000000 -x 161 16384 -x 162 16384 -cci /tmp/nvfortranrsUjZ-Ke_dvo.cci -cmdline ‘+nvfortran diffuse_Y-ACC_Y-OMP_Y-DC-R/diffuse.f -o diffuse_3_Y-ACC_Y-OMP_Y-DC-R.o -c -O3 -Mvect=simd -I/opt/psi/nv/ext_deps/deps/hdf4/include -I/opt/psi/nv/ext_deps/deps/hdf5/include -I/opt/psi/nv/ext_deps/deps/jpeg/include -I/opt/psi/nv/ext_deps/deps/zlib/include -acc=multicore -stdpar=multicore -Minfo=accel’ -stbfile /tmp/nvfortranzsUjl_Svcg9N.stb -asm /tmp/nvfortran5sUjRLrPabVs.ll
