If I want to compile the following loop section
#pragma acc region
#pragma acc for parallel private(ip,ir)
FORALL
dtw_0[ip][ir] += 0.5*hval[ir]*(visc_w_2d[ip ][ir+1] - visc_w_2d[ip ][ir-1])*0.5*hval[ir]*(w_0[ip ][ir+1] - w_0[ip ][ir-1]);
pgcc tells me
pgcc -mp -O3 -Mnoopenmp -ta=nvidia -Minfo=accel -fast -Msafeptr ...
PGC-F-0000-Internal compiler error. Generating a negative offset into dimension of target array 1 (c/esel.c: 1383)
PGC/x86-64 Linux 9.0-4: compilation aborted
But pgcc compiles fine without -ta=nvidia -Minfo=accel, I tried also #pragma acc for host without an effect. What are my options?
Secondly, I would ask why pgcc doesn’t show the correct line number of the source code where the problem was detected?
Thank you!
With kind regards,
Futher information
#define FORALL for(ip = 0; ip < ny; ip++) for(ir = 0; ir < nx; ir++)
/* allocate the matrix */
double **field;
sizey = (size_t)(ny + 2*offy);
sizex = (size_t)(nx + 2*offx );
field = (double **)CALLOC(sizey, sizeof(double *))+offy;
field[-offy] = (double *)CALLOC(sizex*sizey,sizeof(double) )+offx;
for(i = 1-offy;i<ny+offy;i++) field[i]=field[i-1]+sizex;
return field;
