compiler option for Opteron revision F
I wonder which compiler option is appropriate for Opteron revision F (Opteron 8218) processors when the compiler PGI 7.0.4 is used? k8-64 or k8-64e?
Yi-An
Hi Yi-An,
k8-64e would be better. If you leave out -tp, the driver should pick the appropriate -tp flag for you.
Hongyon
Hi hongyon,
Thank you for your reply. Will you provide some new specific optimization for Opteron F processors in the new version of PGI? For example, the new “k8-64f” compiler option?
Thank you for your kind attention.
Yi-An
Hi Yi-An,
No, we don’t have a plan on k8-64f, k8-64e is optimized for both revision E as well as revision F.
Hongyon
