Compiler option to convert 'int' to 'long int'?
Hi all,
Is there a compiler option to convert ‘int’ to ‘long int’ within a C++ code? If not, what do you suggest as the easiest way to do this without manually changing all occurrences in the source.
Regards,
Tim.
There is no compiler option for that. I would do it manually or use some scripts to change source. I would not recommend any other method because of include files and system routines.
Hongyon
Thanks Hongyon for confirming my suspicions…
Much appreciated.
