My 500,000 line Fortran95 program was crashing the pgfortran 12.4 compiler when I tried to introduce a mirror directive. In trying to boil it down to a reproducible example, I’ve got it down to the following 6 lines:
MODULE test
IMPLICIT NONE
REAL(kind=kind(1.d0)) a(1409)
INTEGER,ALLOCATABLE :: arse(:)
!$acc mirror (arse)
END MODULE test
If I compile that with ‘pgfortran -ta=nvidia test.f90’, I get :
pgfortran-Fatal-/home/user/bin/pgi/linux86-64/12.4/bin/pgf902 TERMINATED by signal 11
Arguments to /home/user/bin/pgi/linux86-64/12.4/bin/pgf902
/home/user/bin/pgi/linux86-64/12.4/bin/pgf902 /tmp/user/pgfortranBMZr3HsbP_R.ilm -fn test.f90 -opt 2 -terse 1 -inform warn -x 51 0x20 -x 119 0xa10000 -x 122 0x40 -x 123 0x1000 -x 127 4 -x 127 17 -x 19 0x400000 -x 28 0x40000 -x 120 0x10000000 -x 70 0x8000 -x 122 1 -x 125 0x20000 -quad -x 59 4 -x 59 4 -tp nehalem -x 120 0x1000 -x 124 0x1400 -y 15 2 -x 57 0x3b0000 -x 58 0x48000000 -x 49 0x100 -x 120 0x200 -astype 0 -x 124 1 -x 163 0x1 -x 186 1 -accel nvidia -x 176 0x140000 -x 177 0x0202007f -cmdline '+pgfortran test.f90 -ta=nvidia' -asm /tmp/user/pgfortranJMZPGoyiKWs.s
where ‘pgfortran --version’ gives me:
pgfortran 12.4-0 64-bit target on x86-64 Linux -tp nehalem
Copyright 1989-2000, The Portland Group, Inc. All Rights Reserved.
Copyright 2000-2012, STMicroelectronics, Inc. All Rights Reserved.
If I reduce the size of the a vector below 1409, then it compiles perfectly well. This has got to be a compiler bug, right?
D.
