Sorry about that. I was using our soon to be released 10.8 version, not 10.6. The crash you’re seeing is due to a bug in 10.6. The work around (below) is to move the accelerator region into the body of the j loop.
% cat particle.f90
program main
real :: particles(20,3), garbage(20,3)
real, parameter :: PI = 4 * atan(1.0)
!$acc data region local(garbage), copyout(particles)
!$acc region
do j = 1, 20
particles(j,1) = 4000
particles(j,2) = 0
particles(j,3) = 0
end do
!$acc end region
do j = 1, 10
!$acc region
do jj = 1, 20
garbage(jj,1) = particles(jj,1) + 0.002
garbage(jj,2) = particles(jj,2) + 2 * PI
garbage(jj,3) = (particles(jj,1) + 1) * sin(particles(jj,2) * 1000)
end do
do jj = 1, 20
particles(jj,1) = garbage(jj,1)
particles(jj,2) = garbage(jj,2)
particles(jj,3) = garbage(jj,3)
end do
!$acc end region
enddo
!$acc end data region
print *, particles(1,1)
end program
% pgf90 -ta=nvidia,keepgpu -V10.6 -fast -Minfo=accel -o particle.out particle.f90 -Mkeepasm -Manno
main:
6, Generating local(garbage(:,:))
Generating copyout(particles(:,:))
8, Generating compute capability 1.0 binary
Generating compute capability 1.3 binary
9, Loop is parallelizable
Accelerator kernel generated
9, !$acc do parallel, vector(20)
CC 1.0 : 4 registers; 20 shared, 16 constant, 0 local memory bytes; 33 occupancy
CC 1.3 : 4 registers; 20 shared, 16 constant, 0 local memory bytes; 25 occupancy
18, Generating compute capability 1.0 binary
19, Loop is parallelizable
19, !$acc do parallel, vector(20)
Cached references to size [20x2] block of 'particles'
CC 1.0 : 12 registers; 180 shared, 172 constant, 28 local memory bytes; 33 occupancy
CC 1.3 : 12 registers; 180 shared, 172 constant, 28 local memory bytes; 25 occupancy
24, Loop is parallelizable
24, !$acc do parallel, vector(20)
CC 1.0 : 5 registers; 20 shared, 72 constant, 0 local memory bytes; 33 occupancy
CC 1.3 : 5 registers; 20 shared, 72 constant, 0 local memory bytes; 25 occupancy
% particle.out
4000.020
