Compiling and flashing rt-aux-cpu-demo
the Nvidia documentation (Jetson Sensor Processing Engine (SPE) Developer Guide: Compiling and Flashing*)
mentions I can do make bin_t19x. , make Docs, etc…
I am using the Makefile located in the rt-aux-cpu-demo directory, and I am getting for example “no rule to make target bin_t19x” ( same for Docs etc…)
Where are the "good Makefile located?
I found (for the Docs) it should be “make documents” and not “make Docs”
However for the platform …the Makefile does not seem to include any label: for the target:
Hi @philippe12, welcome to the NVIDIA developer forums!
Did you know that we have dedicated Jetson forums? If you tell me which Jetson you are using I can simply move your post to the most fitting category where there are better experts around.
Oh i did not know. I am using jetson xavier nx
No worries, we do have quite a big number of categories.
Move is done.
what L4T version did you use?
I just verified on r35.3.1, and I can successfully build with make bin_t19x and make bin_t23x.
They are properly placed inside Makefile:
ALL_BUILD_TARGETS := bin_t19x bin_t23x docs
Also, did you use the right compiling toolchain?
Thank you.
My tool chain is correct, but I am using the kernel_src_Xavier-NX-TX2_R32.6.1.tbz2
Where did you get this file from? Is is from NVIDIA’s website?
I think you should use this one for compiling SPE binaries:
https://developer.nvidia.com/embedded/l4t/r32_release_v6.1/sources/t186/l4t_rt_aux_cpu_src.tbz2
Please also check the correct document:
(Sounds like you are working with r32.6.1, but the link to the document you posted is for r35.1)
https://docs.nvidia.com/jetson/archives/spe-archived/spe-3261/index.html
Thank you! I could now match the Documentation and the SPE files …
