I am trying to modify nvidia-uvm.ko. I downloaded NVIDIA-Linux-x86_64-390.48.run and extracted the code. I compiled it without any modifications which gave me: nvidia-drm.ko, nvidia-modeset.ko, nvidia.ko, nvidia-uvm.ko
I then used the following steps:
- lsmod | grep nvidia
nvidia_uvm 671744 0
nvidia_drm 45056 0
nvidia_modeset 860160 1 nvidia_drm
nvidia 13139968 2 nvidia_modeset,nvidia_uvm
drm_kms_helper 167936 1 nvidia_drm
drm 360448 3 nvidia_drm,drm_kms_helper
- sudo rmmod nvidia-uvm # nvidia-uvm was already installed at boot time in my machine
- sudo insmod ./nvidia-uvm.ko
No errors were encountered. But then when I run my CUDA code, it gets stuck. Ctrl-C doesn’t end the program so I am guessing that the code is stuck inside kernel. The CUDA code was working fine before.
Can someone tell me if I am doing something wrong? Are there any arguments that need to be passed when installing the module?
