Hey,
I have a module for some particle tracking stuff written in f90, and I want to couple it to a some fluid flow solver which is written in f77.
The problem I’m facing is in generating the make file .
Since the code source code is spread over various directories, the original makefile for f77 code used to create the makefile (generatiing dependencies) on the fly. This works well with f77 code but with f90 code I will have to show the path to the used modules also by -I (right?)
The makefile puts all the *.o files in a separate OBject file folder. For f90, I’m able to put the *.o files in this Object folder but *.mod files wont go there …
Just that it makes sense I’m copy pasting some part of my makefile hereunder…
Please note that the steinli_interface.f90 is the interface I want to link with my f90 module
Nom du compilateur, nom de l’editeur de liens
CC = pgf90
LINK = pgf90
Options de compilation, options a l’edition de liens
NONEC = -c
DEBUGC = -c -g -r8
OPTIMC = -c -O2 -r8
PROFLC = -c -u -O
DEBUGR8C = -c -u -xtypemap=real:64 -g
OPTIMR8C = -c -fast -stackvar -autopar -xtypemap=real:64
PROFLR8C = -c -u -xtypemap=real:64 -O
NONEL =
DEBUGL = -g -r8
OPTIML = -O2 -r8
PROFLL = -u -O
DEBUGR8L = -g
OPTIMR8L = -fast -stackvar -autopar -xtypemap=real:64
PROFLR8L = -u -xtypemap=real:64 -O
Option de redirection des objets
OPTR = -o "
MPTR = -mod "
Parametres for Makefile
Repertoire des fichiers sources
DSR = .
Repertoire des objets pour les fichiers sources
qui ne sont pas dans le repertoire courant
DOBJ = LINKO
Prefix pour les noms des objets
PRE = OPTIM_
Type – compilation
OPTC = $(OPTIMC)
OPTL = $(OPTIML)
Name of executable file
EXEC = runInPetto
DPO = $(DOBJ)/
#/$(PRE)
List the objet files
LOBJ =
$(DPO)steinli_interface.o
$(DPO)flw_main.o
$(DPO)flw_basic_init.o
$(DPO)flw_global_init.o
$(DPO)flw_ope.o
$(DPO)flw_equ.o
$(DPO)lmn_main.o
$(DPO)mjrm_solver.o
$(DPO)iowa_solver.o
$(DPO)ctz_solver.o
$(DPO)flwP_graph.o
$(DPO)flwP_main.o
$(DPO)flwP_padetest.o
$(DPO)flwP_poissontest.o
$(DPO)fil_main.o
$(DPO)fil_share.o
$(DPO)fil_manag.o
$(DPO)grid_main.o
$(DPO)cpu.o
$(DPO)dimension.o
$(DPO)thomas.o
$(DPO)ind.o
$(DPO)surfop.o
$(DPO)minmax.o
$(DPO)tools.o
$(DPO)graphfile.o
$(DPO)der.o
$(DPO)der_sub_vec.o
$(DPO)der_subbox_vec.o
$(DPO)bound_surfop.o
$(DPO)lmn_bd_main.o
$(DPO)flwL_heat.o
$(DPO)flwL_main.o
$(DPO)flwL_turb.o
$(DPO)acc_bd_main.o
$(DPO)misc.o
$(DPO)profiles.o
$(DPO)rnd.o
$(DPO)share_fil.o
$(DPO)fft_.o
$(DPO)fft_sub.o
$(DPO)fft_spt.o
$(DPO)geneturb_tools.o
$(DPO)filter_main.o
$(DPO)les_main_anup.o
$(DPO)les_sub.o
$(DPO)flwPOI_fft.o
$(DPO)flwPOI_fsh.o
$(DPO)flwPOI_main.o
$(DPO)flwPOI_mud.o
$(DPO)comf.o
$(DPO)fftpack.o
$(DPO)genbun.o
$(DPO)gnbnaux.o
$(DPO)hw3crt.o
$(DPO)hwscrt.o
$(DPO)pois3d.o
$(DPO)cud2sp.o
$(DPO)mud2sp.o
$(DPO)mud3sp.o
$(DPO)mudcom.o
Construction of Dependencies for the executable
$(EXEC) : $(LOBJ)
$(LINK) $(OPTL) -o $(EXEC) $(LOBJ)
Dependances at compilation stage for source files
$(DPO)steinli_interface.o $(DPO)steinli_interface.mod:
$(DSR)/LINK/SOURCE/FLOW/steinli_interface.f90
$(CC) -O2 -I$(DSR)/LINK/SOURCE/STEINLI/ -I$(DSR)/LINK/SOURCE/SHARED_MODULES/
-c $(DSR)/LINK/SOURCE/FLOW/steinli_interface.f90 $(OPTR)$(DPO)steinli_interface.o"
$(DPO)flw_main.o:
$(DSR)/LINK/SOURCE/FLOW/flw_main.f90
$(DSR)/LINK/SOURCE/BOUND/bound.param
$(DSR)/LINK/SOURCE/FLOW/flw_dim.common
$(DSR)/LINK/SOURCE/FLOW/flw_dim.param
$(DSR)/LINK/SOURCE/FLOW/flw_flow.common
$(DSR)/LINK/SOURCE/FLOW/flw_lmn.common
$(DSR)/LINK/SOURCE/FLOW/flw_lmn.param
$(DSR)/LINK/SOURCE/FLOW/flw_run.common
$(DSR)/LINK/SOURCE/FLOW/lag_mod.param
$(DSR)/LINK/SOURCE/GRID/grid.common
$(DSR)/LINK/SOURCE/GRID/grid.param
$(CC) $(OPTC) $(DSR)/LINK/SOURCE/FLOW/flw_main.f90 $(OPTR)$(DPO)flw_main.o"
$(DPO)flw_basic_init.o:
$(DSR)/LINK/SOURCE/FLOW/flw_basic_init.f
$(DSR)/LINK/SOURCE/FILES/fil.common
$(DSR)/LINK/SOURCE/FILES/fil_ind.common
$(DSR)/LINK/SOURCE/FLOW/flw_ite.common
$(DSR)/LINK/SOURCE/FLOW/flw_ref.common
$(CC) $(OPTC) $(DSR)/LINK/SOURCE/FLOW/flw_basic_init.f $(OPTR)$(DPO)flw_basic_init.o"
Any help will be appreciated
Rahul
