phirus
July 9, 2011, 11:53am
1
i don’t know why but if we compile with nvcc a file with .c extension don’t create the default this EV CUDACC like say in the nvcc compile. I check that is created when the file is *.cu
is this normal??? i think that is a mistake. what do u think???
// IMPLEMENTACION DE FUNCIONES EXTERNAS
extern vector * Crear_Vec (int n_row){
vector *vect = (vector *) malloc (sizeof(vector));
vect->len = n_row;
vect->PTR = (double *) malloc (n_row * sizeof(TIPO));
#ifdef __CUDACC__
cudaError_t status = cudaMalloc ((void**)&vect->d_ptr, vect->len * sizeof (TIPO));
if (status != OK_CUDA){
printf("ERROR: al reservar memoria para el fichero en la GPU\n");
free (vect->PTR);
free (vect);
return NULL;
printf ("cuda flag\n");
#endif
printf ("created \n");
return vect;
if i compile *.c with nvcc I only get the message of “created” and if i compile *.cu with nvcc i get the 2 messages
it’s enought with this example???
tera
July 9, 2011, 9:13pm
3
What happens if you compile with [font=“Courier New”]nvcc -x cu[/font]?
phirus
July 10, 2011, 10:06am
4
Ohhhhhhhhhhhhhhhhh it’s works
ok thx u very much i understand now, sorry i didn’t read the help text of nvcc
in addition i had another problem the execution and this have solved it :S:S. Look i compiled with this way
nvcc -G -g -arch=sm_20 -O3 -Xcompiler -Wall -x cu vector.cu matrix.cu -I../include/ -c ###to generate data structures
nvcc -G -g -arch=sm_20 -O3 -Xcompiler -Wall -Xcompiler -fPIC -x cu -I../include/ grad_conj.cu -c ###to generate function
nvcc -shared -Xlinker -soname,libgrad_conj_cublas.so.1 grad_conj.o -o ../lib/libgrad_conj_cublas.so.1.0 -lcublas ###to generate shared lib of function
ln -sf libgrad_conj_cublas.so.1.0 ../lib/libgrad_conj_cublas.so.1
ln -sf libgrad_conj_cublas.so.1 ../lib/libgrad_conj_cublas.so
<b>gcc main.c -Wall -g -O3 -I../include -c -o main.o</b> ###to generate the main program (only prepare the structures and call to library function)
gcc -Wall -g -O3 main.o estructuras/vector.o estructuras/matrix.o -L../lib -lgrad_conj_cublas -o ../bin/grad_conj_cublas ###to link all parts
and now …
<b>nvcc main.c -G -g -arch=sm_20 -O3 -x cu -I../include -c -o main.o</b> ###to generate the main program (only prepare the structures and call to library function)
In the first case the program crash at moment to call function of cublas and free memory (all in grad_conj.cu) and in the second case works perfectly
calling to cublasDdot on grad_conj.cu:
the cublasStatus_t (error) was :EXECUTION FAILED
for this reason (error) i started to free the local variables and …
calling to cudaFree of local variables on grad_conj.cu:
the error was cudaErrorLaunchFailure
the description of cudaGetErrorString(error[0]) was unspecified launch failure
:S:S:S
so… THANK YOU VERY MUCH for the tell me the option -x cu. i don’t know why works now but works hahaha
tera
July 10, 2011, 11:43am
5
[font=“Courier New”]-x cu[/font] tells [font=“Courier New”]nvcc[/font] to compile your code as CUDA code. Otherwise nvcc deduces the language from the file extension, thus compiling your code as ordinary C code.
