Compiling Caffe SSD on Jetson TX1 (Ubuntu 16.04)
The error I get:
/usr/bin/ld: cannot find -lopenblas
collect2: error: ld returned 1 exit status
Makefile:568: recipe for target ‘.build_release/lib/libcaffe.so.1.0.0-rc3’ failed
The changes I made:
Makefile.config
#INCLUDE_DIRS := (PYTHON_INCLUDE) /usr/local/include #LIBRARY_DIRS := (PYTHON_LIB) /usr/local/lib /usr/lib
INCLUDE_DIRS := (PYTHON_INCLUDE) /usr/local/include /usr/include/hdf5/serial/ LIBRARY_DIRS := (PYTHON_LIB) /usr/local/lib /usr/lib /usr/lib/aarch64-linux-gnu/hdf5/serial/
Makefile
#LIBRARIES += glog gflags protobuf boost_system boost_filesystem boost_regex m hdf5_hl hdf5
LIBRARIES += glog gflags protobuf boost_system boost_filesystem m hdf5_serial_hl hdf5_serial
NVCCFLAGS += -ccbin=(CXX) -Xcompiler -fPIC (COMMON_FLAGS)
NVCCFLAGS += -D_FORCE_INLINES -ccbin=(CXX) -Xcompiler -fPIC (COMMON_FLAGS)
Any leads will be appreciated.
Looks for linking libcaffe.so, the linker fails to find libopenblas.so.
Do you have openblas installed ?
sudo apt search openblas |grep installed
should tell you if you have a version installed.
If not, you have to install openblas first :
sudo apt-get install libopenblas-base
When or if already installed, you have to find in which folder is installed libopenblas.so.
If libopenblas.so is in standard /usr/lib, you can skip this step.
Otherwise, add this path to to environment variable LD_LIBRARY_PATH.
For example, if libopenblas.so is in folder /opt/openblas/lib, in your shell type
export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/opt/openblas/lib
for adding this path into the dynamic libs folders.
Then retry make.
i have same problem on jetson tx2
i tried the this solution but it still have the same error
-lopenblas
as it
appear
/usr/bin/ld/:cannot find -lopenblas
Hi ehabo333,
Please file your issue into TX2 board - https://devtalk.nvidia.com/default/board/188/jetson-tx2/
