Compiling CUDA and Cg
I have CUDA 2.1 installed and wish to compile a program that uses both CUDA and Cg.
I’ve downloaded and installed Cg2.2 (using the OSX .dmg file). It has installed successfully; example programs compile and execute.
My problem is how to set up a makefile to compile and link a program that uses both CUDA and Cg.
  • the Cg examples use the -framework Cg parameter
  • nvcc dislikes -framework parameters, so I am trying to set up the makefile to do explicit linking of the library files.
  • I cannot locate where the Cg installer has installed libCg.dylib etc …
Does anyone know where the library files are installed on OSX, or any other method for compiling and linking .cu and .cg files.
thanks
David
Just do your linking with gcc / g++. nvcc can compile object files with the -c parameter.
