Hi, I’m trying to create a module with Cuda for Python to do some FFT work; however, I’m not really sure how I should compile it. I’m haven’t been using Linux that long so I’m not sure about some of the details behind .so files.
I’ve been searching the internet for examples, but thus for I only get errors: ./tiny.so: undefined symbol: __cudaTextureFetch, ImportError: dynamic module does not define init function (inittiny), stuff like that.
I’m using the 64bit sdk. Basically all i did for the .cu file is take an already working python module I was testing and included cutil.h.
Alright, cool. I got it to compile and i and load the module into python.
Now for the last thing standing in my way; any tips on how to convert a Numpy 3d array into a Cuda 3d array?
I had a way of converting a Numpy 3d array to a c 3d array (in my example code), but it looks a little different with Cuda; although I might be overlooking something.
When running some of my test code and PyStream’s cufft_demo code, i get:
cufft: ERROR: /root/cuda-stuff/sw/gpgpu_rel1.1/cufft/src/config.cu, line 106
cufft: ERROR: CUFFT_INTERNAL_ERROR
along with some plan problems.
Could this be a deeper problem?
EDIT: Alright, I updated to the newest drivers: 169.04, and I no longer get the cufft errors; however, I still get a segmentation fault, but I just reran it, so I’ll try debugging it.
You can also take a look at ftp://ftp.graviscom.de/pub/code/python-cuda. It provides Python bindings for CUDA (no FFTs though, but you might be able to add that) and contains some examples, where .cu files have been used from Python, by first compiling them to .cubin files and then loading kernels contained in the .cubin files. The Python CUDA bindings are LGPL,
if it does not say somewhere in the code - I wrote them.
