I try to use a function pointer with template, but I encounter a problem with PGI C++ version new than 9.0. The code is as below.
#include <iostream>
#include <iomanip>
#include <cmath>
using namespace std;
template <class>
struct test
typedef void (*Cptr[2])(T3 a, T4 b);
template <class>
void add(T3 a, T4 b)
cout << "\nAdd" << a << " and " << b;
return;
template <class>
void mi(T3 a, T4 b)
cout << "\nMinus" << a << " and " << b;
return;
template <class>
void assigntest(void (*Cptr[2])(T3 a, T4 b))
Cptr[0] = add<T3>;
Cptr[1] = mi<T3>;
return;
template <class>
void TestingRegion(T3 a, T4 b)
test<T3>::Cptr object;
assigntest(object);
add(a, b);
mi(a,b);
return;
int main()
double a = 1.0, b = 2.0;
int c = 3, d = 4, flag = 0;
TestingRegion(a,b);
TestingRegion(c,d);
return 0;
The above codes work fine with PGI C++ 9.0, but it encounter error in version > 10.0 with the following message:
"test.cpp", line 46: error: expected a ";"
"test.cpp", line 47: error: identifier "object" is undefined
assigntest(object);
"test.cpp", line 47: error: no instance of function template "assigntest"
matches the argument list
argument types are: (<error>)
assigntest(object);
3 errors detected in the compilation of "test.cpp".
I used the same option to compile in both versions (-Kieee -fastsse -Mipa=fast,inline -mp -w). What should I do to correct this problem?
Can you double check that the code posted is correct? I get the following errors with both pgcpp (all versions) and g++.
% g++ test.cpp
test.cpp:10: error: ‘T3’ has not been declared
test.cpp:10: error: ‘T4’ has not been declared
test.cpp:14: error: variable or field ‘add’ declared void
test.cpp:14: error: template declaration of ‘int add’
test.cpp:14: error: ‘T3’ was not declared in this scope
test.cpp:14: error: ‘T4’ was not declared in this scope
test.cpp:21: error: variable or field ‘mi’ declared void
test.cpp:21: error: template declaration of ‘int mi’
test.cpp:21: error: ‘T3’ was not declared in this scope
test.cpp:21: error: ‘T4’ was not declared in this scope
test.cpp:28: error: variable or field ‘assigntest’ declared void
test.cpp:28: error: template declaration of ‘int assigntest’
test.cpp:28: error: ‘Cptr’ was not declared in this scope
test.cpp:28: error: ‘T3’ was not declared in this scope
test.cpp:28: error: ‘T4’ was not declared in this scope
test.cpp:28: error: void value not ignored as it ought to be
test.cpp:36: error: variable or field ‘TestingRegion’ declared void
test.cpp:36: error: template declaration of ‘int TestingRegion’
test.cpp:36: error: ‘T3’ was not declared in this scope
test.cpp:36: error: ‘T4’ was not declared in this scope
test.cpp: In function ‘int main()’:
test.cpp:50: error: ‘TestingRegion’ was not declared in this scope
The code "test<T3,T4::Cptr object; " (the missing > is intensional) is ambiguous since it could be a type or a data member. The 9.0 compiler was not correctly discovering this.
The fix is is to use the typename keyword. “typename test<T3,T4::Cptr object;”.
Note that without “typename”, the code will fail to compiler with g++ as well.
Hope this helps,
Mat
Note that our user forum software has problems when multiple strings are enclosed in “<>”.
