Hi there,
I’m trying to compile the examples that cames with sdk of cuda 2.3, but I got some errors.
Anyone knows why? I can see some bad include pointing to non-existing files…
Follows the make output.
best regards
Lorenzo
make[1]: Entering directory /home/strozzino/NVIDIA_GPU_Computing_SDK/C/common' In file included from src/bank_checker.cpp:15: ./../common/inc/bank_checker.h:34: warning: type qualifiers ignored on function return type ./../common/inc/bank_checker.h:220: warning: type qualifiers ignored on function return type src/bank_checker.cpp:57: warning: type qualifiers ignored on function return type src/bank_checker.cpp:259: warning: type qualifiers ignored on function return type In file included from ./../common/inc/stopwatch.h:18, from src/cutil.cpp:34: ./../common/inc/stopwatch_base.h:56: warning: type qualifiers ignored on function return type ./../common/inc/stopwatch_base.h:60: warning: type qualifiers ignored on function return type In file included from ./../common/inc/stopwatch_base.h:72, from ./../common/inc/stopwatch.h:18, from src/cutil.cpp:34: ./../common/inc/stopwatch_base.inl:67: warning: type qualifiers ignored on function return type ./../common/inc/stopwatch_base.inl:78: warning: type qualifiers ignored on function return type In file included from ./../common/inc/stopwatch.h:25, from src/cutil.cpp:34: ./../common/inc/stopwatch_linux.h:46: warning: type qualifiers ignored on function return type ./../common/inc/stopwatch_linux.h:50: warning: type qualifiers ignored on function return type ./../common/inc/stopwatch_linux.h:126: warning: type qualifiers ignored on function return type ./../common/inc/stopwatch_linux.h:143: warning: type qualifiers ignored on function return type In file included from src/cutil.cpp:34: ./../common/inc/stopwatch.h:35: warning: type qualifiers ignored on function return type In file included from src/cutil.cpp:35: ./../common/inc/bank_checker.h:34: warning: type qualifiers ignored on function return type ./../common/inc/bank_checker.h:220: warning: type qualifiers ignored on function return type src/cutil.cpp: In function ‘CUTBoolean<unnamed>::loadPPM(const char*, unsigned char**, unsigned int*, unsigned int*, unsigned int*)’: src/cutil.cpp:171: warning: ignoring return value of ‘char* fgets(char*, int, FILE*)’, declared with attribute warn_unused_result src/cutil.cpp:193: warning: ignoring return value of ‘char* fgets(char*, int, FILE*)’, declared with attribute warn_unused_result src/cutil.cpp:228: warning: ignoring return value of ‘size_t fread(void*, size_t, size_t, FILE*)’, declared with attribute warn_unused_result In file included from ./../common/inc/stopwatch.h:18, from src/stopwatch.cpp:17: ./../common/inc/stopwatch_base.h:56: warning: type qualifiers ignored on function return type ./../common/inc/stopwatch_base.h:60: warning: type qualifiers ignored on function return type In file included from ./../common/inc/stopwatch_base.h:72, from ./../common/inc/stopwatch.h:18, from src/stopwatch.cpp:17: ./../common/inc/stopwatch_base.inl:67: warning: type qualifiers ignored on function return type ./../common/inc/stopwatch_base.inl:78: warning: type qualifiers ignored on function return type In file included from ./../common/inc/stopwatch.h:25, from src/stopwatch.cpp:17: ./../common/inc/stopwatch_linux.h:46: warning: type qualifiers ignored on function return type ./../common/inc/stopwatch_linux.h:50: warning: type qualifiers ignored on function return type ./../common/inc/stopwatch_linux.h:126: warning: type qualifiers ignored on function return type ./../common/inc/stopwatch_linux.h:143: warning: type qualifiers ignored on function return type In file included from src/stopwatch.cpp:17: ./../common/inc/stopwatch.h:35: warning: type qualifiers ignored on function return type src/stopwatch.cpp:71: warning: type qualifiers ignored on function return type In file included from src/stopwatch_linux.cpp:15: ./../common/inc/stopwatch_linux.h:46: warning: type qualifiers ignored on function return type ./../common/inc/stopwatch_linux.h:50: warning: type qualifiers ignored on function return type ./../common/inc/stopwatch_linux.h:126: warning: type qualifiers ignored on function return type ./../common/inc/stopwatch_linux.h:143: warning: type qualifiers ignored on function return type a - obj/release/bank_checker.cpp.o a - obj/release/cmd_arg_reader.cpp.o a - obj/release/cutil.cpp.o a - obj/release/stopwatch.cpp.o a - obj/release/stopwatch_linux.cpp.o a - obj/release/multithreading.cpp.o make[1]: Leaving directory
/home/strozzino/NVIDIA_GPU_Computing_SDK/C/common’
make[1]: Entering directory /home/strozzino/NVIDIA_GPU_Computing_SDK/C/common' make[1]: Leaving directory
make[1]: Entering directory /home/strozzino/NVIDIA_GPU_Computing_SDK/C/common' In file included from ./../common/inc/rendercheck_gl.h:23, from src/rendercheck_gl.cpp:28: ./../common/inc/GL/glew.h:1123:20: error: GL/glu.h: No such file or directory In file included from ./../common/inc/rendercheck_gl.h:31, from src/rendercheck_gl.cpp:28: ./../common/inc/nvShaderUtils.h: In function ‘GLuint nv::CompileGLSLShaderFromFile(GLenum, const char*)’: ./../common/inc/nvShaderUtils.h:89: warning: ignoring return value of ‘size_t fread(void*, size_t, size_t, FILE*)’, declared with attribute warn_unused_result ./../common/inc/nvShaderUtils.h: In function ‘GLuint nv::CompileASMShaderFromFile(GLenum, const char*)’: ./../common/inc/nvShaderUtils.h:219: warning: ignoring return value of ‘size_t fread(void*, size_t, size_t, FILE*)’, declared with attribute warn_unused_result src/rendercheck_gl.cpp: At global scope: src/rendercheck_gl.cpp:54: warning: unused parameter ‘bQAReadback’ src/rendercheck_gl.cpp:54: warning: unused parameter ‘bUseFBO’ src/rendercheck_gl.cpp: In member function ‘virtual bool CheckRender::PGMvsPGM(const char*, const char*, float, float)’: src/rendercheck_gl.cpp:144: warning: too many arguments for format src/rendercheck_gl.cpp: In member function ‘virtual bool CheckRender::PPMvsPPM(const char*, const char*, float, float)’: src/rendercheck_gl.cpp:190: warning: too many arguments for format src/rendercheck_gl.cpp:183: warning: unused variable ‘src_data’ src/rendercheck_gl.cpp:183: warning: unused variable ‘ref_data’ src/rendercheck_gl.cpp: In member function ‘virtual bool CheckRender::compareBin2BinUint(const char*, const char*, unsigned int, float, float)’: src/rendercheck_gl.cpp:226: warning: too few arguments for format src/rendercheck_gl.cpp:228: warning: too many arguments for format src/rendercheck_gl.cpp:246: warning: ignoring return value of ‘size_t fread(void*, size_t, size_t, FILE*)’, declared with attribute warn_unused_result src/rendercheck_gl.cpp:247: warning: ignoring return value of ‘size_t fread(void*, size_t, size_t, FILE*)’, declared with attribute warn_unused_result src/rendercheck_gl.cpp: In member function ‘virtual bool CheckRender::compareBin2BinFloat(const char*, const char*, unsigned int, float, float)’: src/rendercheck_gl.cpp:288: warning: too few arguments for format src/rendercheck_gl.cpp:290: warning: too many arguments for format src/rendercheck_gl.cpp:308: warning: ignoring return value of ‘size_t fread(void*, size_t, size_t, FILE*)’, declared with attribute warn_unused_result src/rendercheck_gl.cpp:309: warning: ignoring return value of ‘size_t fread(void*, size_t, size_t, FILE*)’, declared with attribute warn_unused_result src/rendercheck_gl.cpp: In member function ‘virtual bool CheckBackBuffer::checkStatus(const char*, int, bool)’: src/rendercheck_gl.cpp:378: error: ‘gluErrorString’ was not declared in this scope src/rendercheck_gl.cpp: At global scope: src/rendercheck_gl.cpp:518: warning: unused parameter ‘Bpp’ src/rendercheck_gl.cpp:545: warning: unused parameter ‘width’ src/rendercheck_gl.cpp:545: warning: unused parameter ‘height’ src/rendercheck_gl.cpp:545: warning: unused parameter ‘Bpp’ src/rendercheck_gl.cpp:560: warning: unused parameter ‘width’ src/rendercheck_gl.cpp:560: warning: unused parameter ‘height’ src/rendercheck_gl.cpp:560: warning: unused parameter ‘Bpp’ src/rendercheck_gl.cpp:702: warning: unused parameter ‘width’ src/rendercheck_gl.cpp:702: warning: unused parameter ‘height’ make[1]: *** [obj/release/rendercheck_gl.cpp.o] Error 1 make[1]: Leaving directory
make: *** [lib/librendercheckgl.so] Error 2
