hi All
I am trying to install CUDA on my macbook with snow leopard 10.6.7 and NVIDIA GeForce 9400M. I follow the getting started guide for Mac OS X but when compiling the Examples (“make”) in the /Developer/GPU Computing/C directory I get the following error (both for 3.2 and 4.0). It seems to me that the make command does not really like my MPI installation, but I have no idea how to solve this issue.
/opt/local/include/mpich2/mpicxx.h:1889: warning: unused parameter ‘oldwin’
/opt/local/include/mpich2/mpicxx.h:1889: warning: unused parameter ‘keyval’
/opt/local/include/mpich2/mpicxx.h:1889: warning: unused parameter ‘ex’
ld: warning: in obj/i386/release/simpleMPI.cu.o, file was built for i386 which is not the architecture being linked (x86_64)
ld: warning: in …/…/lib/libcutil_i386.a, file was built for unsupported file format which is not the architecture being linked (x86_64)
ld: warning: in …/…/…/shared//lib/libshrutil_i386.a, file was built for unsupported file format which is not the architecture being linked (x86_64)
Undefined symbols for architecture x86_64:
“_sum”, referenced from:
_main in simpleMPI.cpp.o
“_initData”, referenced from:
“_computeGPU”, referenced from:
ld: symbol(s) not found for architecture x86_64
collect2: ld returned 1 exit status
ld: warning: in /opt/local/lib/libmpichcxx.dylib, file was built for unsupported file format which is not the architecture being linked (i386)
ld: warning: in /opt/local/lib/libpmpich.dylib, file was built for unsupported file format which is not the architecture being linked (i386)
ld: warning: in /opt/local/lib/libmpich.dylib, file was built for unsupported file format which is not the architecture being linked (i386)
ld: warning: in /opt/local/lib/libopa.a, file was built for unsupported file format which is not the architecture being linked (i386)
Undefined symbols for architecture i386:
“_MPI_Finalize”, referenced from:
“_MPI_Scatter”, referenced from:
“_MPI_Comm_size”, referenced from:
“_MPI_Comm_rank”, referenced from:
“_MPI_Init”, referenced from:
“_MPI_Reduce”, referenced from:
“_MPI_Abort”, referenced from:
_my_abort in simpleMPI.cpp.o
ld: symbol(s) not found for architecture i386
lipo: can’t open input file: /var/folders/64/64RSjzx5GVOWYNxkioIjTE+++TI/-Tmp-//ccs062il.out (No such file or directory)
make[1]: *** […/…/bin/darwin/release/simpleMPI] Error 1
make: *** [src/simpleMPI/Makefile.ph_build] Error 2
Jan-Decas-MacBook:C jandeca$
Many thanks and best regards
Jan
