I have a program that runs very well in 32-bit mode. I wanted some additonal performance and hopefully some additonal parameter when I run the PGroup Profiler for Linux Workstation c/c++. So I just tried to port the code to 64 bit workstation. I changed nothng in the source code and just changed the path so it now points to the 64 bit pgcc instead of the 32 bit pgcc.
I made some small modifications to my Makefile and then typed make.
The compile line was the same, but it choked on three line in my thread.c file. The output is:
gcc -c -Wall -O0 -Mino=ccff -Mprof=func thread.c -o thread.o
thread.c: In function ‘CreateThread’:
thread.c:67: warning: format ‘%u’ expects type ‘unsigned int’, but argument 2 has type ‘size_t’
thread.c:67: warning: format ‘%x’ expects type ‘unsigned int’, but argument 3 has type ‘size_t’
thread.c:67: warning: format ‘%o’ expects type ‘unsigned int’, but argument 4 has type ‘size_t’
The CreateThread function is now shown:
/Print out size of stack/
if(pthread_attr_getstacksize(&thread_attr, &stack_size) !=0){
printf("%s - line %d; CreateThread: pthread_attr_getstacksize - getstacksize error!!\n"
, FILE, LINE);
return(-1);
printf(“Pthread: Stack size = %u decimal, %x hexadecimal, %o octal\n”,
stack_size,stack_size,stack_size );
return(0);
The line in question is the printf statement that extends on to another line. What is the problem (if there is one) and how do i fix it?
Please note that the program does compile and run. This is only a warning, but I am just wondering if something deeper is wrong.
Thanks in advance.
THX 1138
