Compiling kernel from the source [help]
Hi! I had some problems compiling the kernel from the source.
kernel: http://nv-tegra.nvidia.com/gitweb/?p=linux-3.10.git;a=summary
head: l4t/l4t-r23.2
Version of linux
root@shieldteam:~/nuevoKernelOriginal/kernel# uname -a
Linux shieldteam 3.16.0-62-generic #83~14.04.1-Ubuntu SMP Fri Feb 26 22:52:39 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
Script for compile
export ARCH=arm64
export CROSS_COMPILE=/usr/bin/aarch64-linux-gnu-
apt-get install gcc-aarch64-linux-gnu
apt-get install gcc-arm-linux-androideabi
export CROSS32CC=arm-linux-androideabi-gcc
export TEGRA_KERNEL_OUT=../tegra21_defconfig
mkdir $TEGRA_KERNEL_OUT
make -j9 mrproper
make -j9 V=2 O=$TEGRA_KERNEL_OUT mrproper
make -j9 V=2 O=$TEGRA_KERNEL_OUT tegra21_defconfig
make -j9 V=2 O=$TEGRA_KERNEL_OUT zImage
Error:
CC      drivers/usb/host/pci-quirks.o - due to target missing
  CC      drivers/usb/misc/usb_nvshieldled.o - due to target missing
  CC      drivers/video/tegra/nvmap/nvmap_init.o - due to target missing
  CC      drivers/video/tegra/host/nvhost_job.o - due to target missing
/root/nuevoKernelOriginal/kernel/drivers/usb/misc/usb_nvshieldled.c: In function ‘nvshieldled_probe’:
/root/nuevoKernelOriginal/kernel/drivers/usb/misc/usb_nvshieldled.c:394:7: warning: passing argument 3 of ‘of_property_read_string’ from incompatible pointer type [enabled by default]
       &edp_name)) {
In file included from /root/nuevoKernelOriginal/kernel/drivers/usb/misc/usb_nvshieldled.c:26:0:
/root/nuevoKernelOriginal/kernel/include/linux/of.h:268:12: note: expected ‘const char **’ but argument is of type ‘char **’
 extern int of_property_read_string(struct device_node *np,
  CC      drivers/video/tegra/dc/clock.o - due to target missing
/root/nuevoKernelOriginal/kernel/drivers/video/tegra/nvmap/nvmap_init.c: In function ‘nvmap_init’:
/root/nuevoKernelOriginal/kernel/drivers/video/tegra/nvmap/nvmap_init.c:328:6: error: ‘err’ may be used uninitialized in this function [-Werror=maybe-uninitialized]
  int err;
cc1: all warnings being treated as errors
make[5]: *** [drivers/video/tegra/nvmap/nvmap_init.o] Error 1
make[4]: *** [drivers/video/tegra/nvmap] Error 2
make[4]: *** Waiting for unfinished jobs....
  CC      drivers/video/tegra/dc/window.o - due to target missing
  LD      drivers/usb/misc/built-in.o - due to target missing
  CC      drivers/usb/phy/phy.o - due to target missing
  CC      drivers/usb/host/ehci-hcd.o - due to target missing
  CC      drivers/video/tegra/dc/csc.o - due to target missing
  CC      drivers/target/target_core_iblock.o - due to target missing
  CC      drivers/video/tegra/host/dev.o - due to target missing
  CC      drivers/usb/host/ehci-pci.o - due to target missing
  CC      drivers/usb/phy/phy-tegra-usb.o - due to target missing
  CC      drivers/usb/host/xhci.o - due to target missing
  CC      drivers/target/target_core_file.o - due to target missing
  CC      drivers/usb/host/xhci-mem.o - due to target missing
  CC      drivers/usb/phy/tegra11x_usb_phy.o - due to target missing
  LD      drivers/target/target_core_mod.o - due to target missing
  LD      drivers/target/built-in.o - due to target missing
  CC      drivers/usb/host/xhci-ring.o - due to target missing
  CC      drivers/video/tegra/host/debug.o - due to target missing
  CC      drivers/video/tegra/host/bus_client.o - due to target missing
  CC      drivers/platform/tegra/wakeups-t21x.o - due to target missing
  CC      drivers/usb/host/xhci-hub.o - due to target missing
  CC      drivers/platform/tegra/kfuse.o - due to target missing
  CC      drivers/video/tegra/host/chip_support.o - due to target missing
  CC      drivers/video/tegra/dc/lut.o - due to target missing
  CC      drivers/usb/phy/tegra-otg.o - due to target missing
  CC      drivers/platform/tegra/apbio.o - due to target missing
  CC      drivers/video/tegra/host/nvhost_scale.o - due to target missing
  CC      drivers/video/tegra/dc/cursor.o - due to target missing
  CC      drivers/usb/host/xhci-dbg.o - due to target missing
  CC      drivers/usb/host/xhci-pci.o - due to target missing
  CC      drivers/platform/tegra/tegra21_dvfs.o - due to target missing
  CC      drivers/video/cfbimgblt.o - due to target missing
  CC      drivers/usb/host/xhci-tegra-t210-padctl.o - due to target missing
  CC      drivers/usb/phy/phy-ulpi.o - due to target missing
  CC      drivers/video/tegra/host/pod_scaling.o - due to target missing
  CC      drivers/usb/phy/phy-ulpi-viewport.o - due to target missing
  CC      drivers/video/sysfillrect.o - due to target missing
  CC      drivers/video/syscopyarea.o - due to target missing
  CC      drivers/video/tegra/dc/rgb.o - due to target missing
  CC      drivers/video/tegra/dc/of_dc.o - due to target missing
  CC      drivers/platform/tegra/tegra21_speedo.o - due to target missing
  LD      drivers/usb/phy/built-in.o - due to target missing
  LD      drivers/usb/host/xhci-hcd.o - due to target missing
  LD      drivers/usb/host/built-in.o - due to target missing
  CC      drivers/usb/serial/usb-serial.o - due to target missing
  CC      drivers/video/sysimgblt.o - due to target missing
  CC      drivers/usb/storage/scsiglue.o - due to target missing
  CC      drivers/video/fb_sys_fops.o - due to target missing
  CC      drivers/platform/tegra/bond_out.o - due to target missing
  CC      drivers/video/tegra/dc/dsi2lvds.o - due to target missing
  CC      drivers/video/tegra/host/nvhost_vm.o - due to target missing
  CC      drivers/platform/tegra/tegra_soctherm.o - due to target missing
  CC      drivers/video/fb_defio.o - due to target missing
  CC      drivers/usb/serial/generic.o - due to target missing
  CC      drivers/usb/storage/protocol.o - due to target missing
  CC      drivers/video/tegra/dc/mipi_cal.o - due to target missing
  CC      drivers/usb/serial/bus.o - due to target missing
  CC      drivers/video/tegra/dc/edid.o - due to target missing
  CC      drivers/video/output.o - due to target missing
  CC      drivers/video/tegra/host/scale3d.o - due to target missing
  CC      drivers/usb/storage/transport.o - due to target missing
  CC      drivers/usb/serial/ftdi_sio.o - due to target missing
  CC      drivers/usb/serial/option.o - due to target missing
  LD      drivers/video/fb.o - due to target missing
  CC      drivers/usb/usb-common.o - due to target missing
  CC      drivers/video/tegra/dc/nvsd.o - due to target missing
  CC      drivers/video/tegra/host/flcn/flcn.o - due to target missing
  CC      drivers/usb/storage/usb.o - due to target missing
  CC      drivers/usb/storage/initializers.o - due to target missing
  CC      drivers/usb/storage/sierra_ms.o - due to target missing
  CC      drivers/usb/serial/pl2303.o - due to target missing
  CC      drivers/platform/tegra/board-common.o - due to target missing
  CC      drivers/usb/serial/usb_wwan.o - due to target missing
  CC      drivers/video/tegra/host/host1x/host1x.o - due to target missing
  CC      drivers/usb/storage/option_ms.o - due to target missing
  LD      drivers/video/tegra/host/flcn/nvhost-flcn.o - due to target missing
  LD      drivers/video/tegra/host/flcn/built-in.o - due to target missing
  CC      drivers/usb/storage/usual-tables.o - due to target missing
  CC      drivers/video/tegra/host/isp/isp_isr_v1.o - due to target missing
  CC      drivers/video/tegra/host/isp/isp.o - due to target missing
  CC      drivers/platform/tegra/board-touch-raydium_spi.o - due to target missing
  LD      drivers/usb/serial/usbserial.o - due to target missing
  CC      drivers/video/tegra/host/nvdec/nvdec.o - due to target missing
  CC      drivers/video/tegra/host/t124/t124.o - due to target missing
  LD      drivers/usb/serial/built-in.o - due to target missing
  LD      drivers/usb/storage/usb-storage.o - due to target missing
  CC      drivers/video/tegra/host/t210/t210.o - due to target missing
  LD      drivers/usb/storage/built-in.o - due to target missing
  LD      drivers/usb/built-in.o - due to target missing
  CC      drivers/video/tegra/host/tsec/tsec.o - due to target missing
  CC      drivers/platform/tegra/board-panel.o - due to target missing
  CC      drivers/video/tegra/dc/dsi.o - due to target missing
  CC      drivers/platform/tegra/gpu-edp.o - due to target missing
  LD      drivers/video/tegra/host/host1x/nvhost-host1x.o - due to target missing
  LD      drivers/video/tegra/host/isp/nvhost-isp.o - due to target missing
  LD      drivers/video/tegra/host/host1x/built-in.o - due to target missing
  LD      drivers/video/tegra/host/isp/built-in.o - due to target missing
  CC      drivers/video/tegra/dc/dsi_debug.o - due to target missing
  CC      drivers/video/tegra/host/vhost/vhost.o - due to target missing
  LD      drivers/video/tegra/host/nvdec/nvhost-nvdec.o - due to target missing
  LD      drivers/video/tegra/host/nvdec/built-in.o - due to target missing
  CC      drivers/video/tegra/host/nvhost_sync.o - due to target missing
  CC      drivers/platform/tegra/asim.o - due to target missing
  CC      drivers/video/tegra/host/vhost/vhost_intr.o - due to target missing
  LD      drivers/video/tegra/host/tsec/nvhost-tsec.o - due to target missing
  LD      drivers/video/tegra/host/tsec/built-in.o - due to target missing
  LD      drivers/video/tegra/host/nvhost.o - due to target missing
  CC      drivers/platform/tegra/mselect.o - due to target missing
  CC      drivers/platform/tegra/tegra_prod.o - due to target missing
  CC      drivers/video/tegra/dc/dc_sysfs.o - due to target missing
  CC      drivers/platform/tegra/reboot.o - due to target missing
  CC      drivers/video/tegra/host/vhost/vhost_syncpt.o - due to target missing
  CC      drivers/video/tegra/host/vhost/vhost_channel.o - due to target missing
  CC      drivers/video/tegra/host/vhost/vhost_cdma.o - due to target missing
  CC      drivers/video/tegra/host/vhost/vhost_client.o - due to target missing
  LD      drivers/platform/tegra/built-in.o - due to target missing
  LD      drivers/video/tegra/host/t210/nvhost-t210.o - due to target missing
  LD      drivers/video/tegra/host/t210/built-in.o - due to target missing
  CC      drivers/video/tegra/dc/dc_config.o - due to target missing
  LD      drivers/video/tegra/host/t124/nvhost-t124.o - due to target missing
  CC      drivers/video/tegra/dc/sor.o - due to target missing
  CC      drivers/video/tegra/dc/dpaux.o - due to target missing
  LD      drivers/video/tegra/host/t124/built-in.o - due to target missing
  CC      drivers/video/tegra/dc/hdmi2.0.o - due to target missing
  CC      drivers/video/tegra/dc/fake_panel.o - due to target missing
  CC      drivers/video/tegra/dc/ext/dev.o - due to target missing
  LD      drivers/platform/built-in.o - due to target missing
  LD      drivers/video/tegra/host/vhost/nvhost-vhost.o - due to target missing
  LD      drivers/video/tegra/host/vhost/built-in.o - due to target missing
  LD      drivers/video/tegra/host/built-in.o - due to target missing
  CC      drivers/video/tegra/dc/ext/util.o - due to target missing
  CC      drivers/video/tegra/dc/ext/cursor.o - due to target missing
  CC      drivers/video/tegra/dc/null_or.o - due to target missing
  CC      drivers/video/tegra/dc/ext/events.o - due to target missing
  CC      drivers/video/tegra/dc/ext/control.o - due to target missing
  LD      drivers/video/tegra/dc/ext/built-in.o - due to target missing
  LD      drivers/video/tegra/dc/built-in.o - due to target missing
make[3]: *** [drivers/video/tegra] Error 2
make[2]: *** [drivers/video] Error 2
make[1]: *** [drivers] Error 2
make: *** [sub-make] Error 2
Complete log:
http://pastebin.com/JvYBXDcq
PD: Sorry for my bad english
