I’ve got a small project that is written mostly in C++, but there’s one file (SDLMain.m) in Objective-C.
When I compile it with g++, it works fine. But when I try using nvcc, I get
nvcc fatal : Don't know what to do with 'SDLMain.m'
How can I tell nvcc to just pass that on to g++ the same as it does with .cpp files?
OK, I found a solution.
My first approach to a solution was to compile the objective-c file using g++
$ g++ -c SDLMain.m
But then the linker had trouble putting the .o files together.
$ nvcc -o sdl_app *.o -lm -Xlinker -framework,SDL,-framework,Cocoa
ld: warning: in SDLMain.o, file was built for unsupported file format which is not the architecture being linked (i386)
Undefined symbols:
"_main", referenced from:
start in crt1.10.6.o
(maybe you meant: _SDL_main)
ld: symbol(s) not found
collect2: ld returned 1 exit status
But what I just found, and what seems to work, is using g++ to compile for i386.
$ nvcc -I. -c main.cpp
$ g++ -arch i386 -I. -c SDLMain.m
$ nvcc -I. -O2 -o sdl_app *.o -lm -Xlinker -framework,SDL,-framework,Cocoa
And rolling that up into a Makefile works just fine.
$ g++ -c SDLMain.m
Undefined symbols:
