I’m following the tutorial on: https://jkjung-avt.github.io/build-tensorflow-2.0.0/
but compiling blaze fails with:
ERROR: /mnt/nvme/tensorflow_install/jetson_nano/src/tensorflow-2.0.0/tensorflow/python/keras/api/BUILD:46:1: Executing genrule //tensorflow/python/keras/api:keras_python_api_gen_compat_v2 failed (Exit 1)
File "/mnt/nvme/.cache/bazel/_bazel_nvidia/98cdf810b71446efc44591ffddb09367/execroot/org_tensorflow/bazel-out/host/bin/tensorflow/python/keras/api/create_tensorflow.python_api_2_keras_python_api_gen_compat_v2.runfiles/org_tensorflow/tensorflow/python/tools/api/generator/create_python_api.py", line 27, in <module>
from tensorflow.python.tools.api.generator import doc_srcs
File "/mnt/nvme/.cache/bazel/_bazel_nvidia/98cdf810b71446efc44591ffddb09367/execroot/org_tensorflow/bazel-out/host/bin/tensorflow/python/keras/api/create_tensorflow.python_api_2_keras_python_api_gen_compat_v2.runfiles/org_tensorflow/tensorflow/python/__init__.py", line 52, in <module>
from tensorflow.core.framework.graph_pb2 import *
File "/mnt/nvme/.cache/bazel/_bazel_nvidia/98cdf810b71446efc44591ffddb09367/execroot/org_tensorflow/bazel-out/host/bin/tensorflow/python/keras/api/create_tensorflow.python_api_2_keras_python_api_gen_compat_v2.runfiles/org_tensorflow/tensorflow/core/framework/graph_pb2.py", line 7, in <module>
from google.protobuf import descriptor as _descriptor
ModuleNotFoundError: No module named 'google.protobuf'
Target //tensorflow/tools/pip_package:build_pip_package failed to build
Use --verbose_failures to see the command lines of failed build steps.
INFO: Elapsed time: 13210.120s, Critical Path: 451.46s
INFO: 11876 processes: 11876 local.
FAILED: Build did NOT complete successfully
but on the other hand if I’m running that line alone it works no problem:
/mnt/nvme/tensorflow_install/jetson_nano$ python3
Python 3.6.9 (default, Nov 7 2019, 10:44:02)
[GCC 8.3.0] on linux
Type "help", "copyright", "credits" or "license" for more information.
>>> exit()
