I need raid drivers on my NX, and after some research it appears the best way to fix this is to recompile the kernel :-/
I’m using this method, which seems like it uses all of the up to date systems.
Doing nothing else than the using the scripts, making the kernel fails due to a compiler issue :
drivers/base/dma-coherent.c:973:12: error: ‘shrink_thread’ defined but not used [-Werror=unused-function]
static int shrink_thread(void *arg)
drivers/base/dma-coherent.c:96:13: error: ‘dma_debugfs_init’ defined but not used [-Werror=unused-function]
static void dma_debugfs_init(struct device *dev, struct heap_info *heap)
drivers/base/dma-coherent.c:280:12: error: ‘declare_coherent_heap’ defined but not used [-Werror=unused-function]
static int declare_coherent_heap(struct device *dev, phys_addr_t base,
cc1: all warnings being treated as errors
scripts/Makefile.build:335: recipe for target ‘drivers/base/dma-coherent.o’ failed
make[2]: *** [drivers/base/dma-coherent.o] Error 1
scripts/Makefile.build:649: recipe for target ‘drivers/base’ failed
make[1]: *** [drivers/base] Error 2
Makefile:1121: recipe for target ‘drivers’ failed
make: *** [drivers] Error 2
Doing some research, it seemed like it’s a compiler mismatch. The version on my system (up-to-date) is 7.5.0 and the recommended version is 7.3.1 in the tool-chain instructions.
I tried downloading the toolchain and setting the cross_compile as per the instructions, but then I get exec format errors which seems to be a result of mismatched architecture? I’m not sure.
l4t-gcc/gcc-linaro-7.3.1-2018.05-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu-gcc: Exec format error
Kbuild:20: recipe for target ‘kernel/bounds.s’ failed
make[1]: *** [kernel/bounds.s] Error 2
Makefile:1166: recipe for target ‘prepare0’ failed
I would prefer not to have to compile this externally and reflash.
