I’m trying to call a CUDA function written in C from a program written in Fortran. I’m pretty certain that all the code is ok, but I’m having trouble pointing the gfortran compiler at the cuda library files. I think it’s to do with the fact that gfortran’s -l option looks for *.a files rather than .lib files…
Here are the commands I use to compile:
nvcc -c -O3 kernel_wrapper.cu
gfortran -c Fortran_C_Interface.f95
gfortran -L$(CUDA_LIB_PATH) -lcudart -lcuda -I$(CUDA_INC_PATH) Fortran_C.f95 kernel_wrapper.obj
Where CUDA_LIB_PATH = C:\CUDA\v3.2\lib\Win32; CUDA_INC_PATH = C:\CUDA\v3.2\include
The first two commands work as expected. However, the last command spits out the following error:
c:/mingw/bin/../lib/gcc/mingw32/4.5.2/../../../../mingw32/bin/ld.exe: cannot find -lcudart
collect2: ld returned 1 exit status
How do I point gfortran at .lib files? Or do I have to process the .lib files into .a or .o files first? Or have I got the syntax all wrong seems as I’m using Windows XP (32 bit) and not Linux?
Any help would be greatly appreciated :)
