Hi. I am having trouble getting things to run properly when the code is compiled with GPU debug information. Inexplicable errors are thrown, and I narrowed it down, from quite a large piece of code to a single line, where I use a functor inside a device function. The code runs quite well when compiled without the gpu debug information (EDIT: I get this problem only when I try to GPU debug). It makes me wonder if the problem is really there or it is a bug with the debugger… here’s a sample of the error I am getting:
First-chance exception at 0x7661b9bc in cudaCLAW.exe: Microsoft C++ exception: cudaError_enum at memory location 0x002af708..
First-chance exception at 0x7661b9bc in cudaCLAW.exe: Microsoft C++ exception: cudaError_enum at memory location 0x002af714..
First-chance exception at 0x7661b9bc in cudaCLAW.exe: Microsoft C++ exception: cudaError_enum at memory location 0x002af674..
First-chance exception at 0x7661b9bc in cudaCLAW.exe: Microsoft C++ exception: cudaError_enum at memory location 0x002af684..
First-chance exception at 0x7661b9bc in cudaCLAW.exe: Microsoft C++ exception: cudaError_enum at memory location 0x002af670..
and this is essentially the device function:
template<..., class Limiter>
__device__ real limiting (Limiter phi, ...)
real var;
// update var, legal short code
if (/*...*/)
return (real)0.0f;
return phi(var); <------------ commenting this line out and replacing it with some constant return runs just fine with the debug info!
The functor phi doesnt read any memory location except the given argument and returns a real.
I can’t explain this, if anybody out there can please let me know what’s going on. Thanks.
