hello,
I got a small problem, I recently came back to c/c++ (after 7 years of java) and started to write a simple application with cuda. The goal is basically to provide a jni interface to several chemical algorithms which are executed on a gt 8800.
Now the challenge it has to run on windows/linux/osx.
so my idea is, have a library which works on plain c → done
have a library which works on c and cuda → done
have a java api which works on c or cuda or falls back to a java implementation.
→ jni access not working
ok now the fun parts:
1. make file to build the jni lib
CUDA_INSTALL_PATH := "C:\Progra~1\NVIDIA~1\NVIDIA~1"
# simple make file for cuda on osx
# Add source files here
BASEDIR=../../../
TARGET_DIR=$(BASEDIR)target/
HEADER=$(TARGET_DIR)include
EXECUTABLE := $(TARGET_DIR)classes/jacuda-jni.dll
CUFILES := jni-similarity.cpp
# Includes
INCLUDES += -I. -I$(CUDA_INSTALL_PATH)/include -I$(COMMONDIR)/inc -I$(HEADER) -I$(TARGET_DIR)/classes -I"$(JAVA_HOME)\include" -I"$(JAVA_HOME)\include\win32"
LIB := -L$(CUDA_INSTALL_PATH)/common/lib -L$(TARGET_DIR)lib -L$(CUDA_INSTALL_PATH)/lib
DOLINK := -lcuda -lcudart -ljacuda-c -ljacuda-cu
device:
nvcc -lib -shared -o $(EXECUTABLE) $(CUFILES) $(INCLUDES) $(LIB) $(DOLINK)
emulate:
nvcc -lib -shared -o $(EXECUTABLE) $(CUFILES) $(INCLUDES) $(LIB) $(DOLINK) -deviceemu
2. my jni class who calls the stuff (for now with an absolute path)
public class Similarity {
* loads our library
static{
System.load("F:\workspaces\c++\JaCuda\target\classes\jacuda-jni.dll");
* calculates the similarities between the unknown and the library spectra
* @param lib
* @param unk
* @return
public static native float[] calculateSimilarity(String[] lib, String[] unk);
and finally i get an error message like:
“is not a win32 application”
anybody got some pointers for me how my make files have to look to make this thing work?
env:
visual c++ express
cygwin
java 1.5
maven 2.0.9
ant 1.6,*
thanks for your help!
Ok after spending some more hours over the problem and rewriting some code I wrote a makefile which works.
Basically my main error was that I wanted to link to many libraries together and sometimes the simplest approach with one library instead of 3 works best.
Anyway attached a makefile which generates a dll under windowsXp/cygwin/visual studio 8 and is able to be accessed using jni.
The complete project can be found under
https://sourceforge.net/projects/jacuda/
BASEDIR=../../
HEADER=$(TARGET_DIR)include/
EXECUTABLE := $(BASEDIR)Jacuda.dll
CUFILES := ./c++/similarity.cpp ./c++/spectra.cpp ./c++/sfunction.cpp ./cuda/similarityCuda.cu ./jni/jni-similarity.cpp ./jni/jni-cuda-similarity.cpp
# Rules and targets
# Includes
INCLUDES += -I. -I"$(CUDA_INC_PATH)" -I$(HEADER) -I"$(JAVA_HOME)/include" -I"$(JAVA_HOME)/include/win32" -I$(TARGET_DIR)classes
#INCLUDES += -I. -I"$(JAVA_HOME)/include" -I$(TARGET_DIR)classes
# Libs
LIB := -L$(CUDA_LIB_PATH)
#LIB :=
#DOLINK :=
device:
cp cuda/*.h $(HEADER)
cp c++/*.h $(HEADER)
nvcc -O3 -shared -o $(EXECUTABLE) $(CUFILES) $(INCLUDES) $(LIB) $(DOLINK)
emulate:
nvcc -O3 -shared -o $(EXECUTABLE) $(CUFILES) $(INCLUDES) $(LIB) $(DOLINK) -deviceemu
clean:
rm -f $(CCOFILES) $(EXECUTABLE)
moreclean: clean
rm -f *.cu.c
the makefile for osx would be
BASEDIR=../../
EXECUTABLE := $(BASEDIR)libJacuda.jnilib
# Rules and targets
CUDA_INSTALL_PATH := /usr/local/cuda
# Includes
INCLUDES += -I. -I$(CUDA_INSTALL_PATH)/include -I$(COMMONDIR)/inc -I$(HEADER) -I/System/Library/Frameworks/JavaVM.framework/Headers -I$(TARGET_DIR)classes
#INCLUDES += -I. -I/System/Library/Frameworks/JavaVM.framework/Headers -I$(TARGET_DIR)classes
# Libs
#LIB :=
#DOLINK :=
device:
mkdir $(HEADER)
emulate:
mkdir $(HEADER)
clean:
moreclean: clean
rm -f *.cu.c
