Completed Course, Building a Brain in 10 Minutes' but grade is still zero and can't get a certificate
For the course, Building a Brain in 10 minutes, I have run the example code snippets and completed the survey at the end.
I would like to obtain a certificate, but it says that my Grade is at 0% and that a grade of 50% is required to pass the course.
I can’t find any task or action to improve my grade. For example I can’t find a link to go to an exam at the end.
Please advise what actions are needed to improve my grade.
Welcome to the forums.
I have reached out to the DLI team for an answer.
Best,
Tom
Same issue here!
Hi @prithvimore33
Your problem may be related to a known issue with the platform. The team is working to resolve this ASAP.
Thanks for your patience,
Tom
Still facing same issue
@mummanajagadeesh97 Please open a new topic with the course title that is giving you the problem.
Couldn’t find any task or assignment to complete
Unfortunately, that course does not offer a certificate.
It should be removed that there are assignments and a certificate offered then.
