Complier returning syntax error for nvocdr.h
I was working with NVIDIA-Optical-Character-Detection-and-Recognition-Solution. Trying to build a Qt application with my custom model. I built and ran the application locally using a make file. It works fine. But when I am trying to build with Qt the compiler in returning error. But the syntax looks correct to me.
Here is the error message:
/home/sigmind/Documents/LOCC2023_Vehicle/WC-Tegra-DS/nvocdrc.h:96: error: expected declaration before ‘}’ token
96 | }
####inplementation of nvocdr.h######
#ifndef NVOCDR_LIB
define NVOCDR_LIB
include <stdint.h>
define MAX_CHARACTER_LEN 64
define MAX_PLY_CNT 8
// The nvOCDR lib’s batch size at images level.
// Maximum 64 images can be feed to nvOCDR at once.
define MAX_BATCH_SIZE 64
ifdef __cplusplus
extern “C”
endif
typedef void* nvOCDRp;
enum nvOCDRStat
SUCCESS,
FAIL
enum Device
CPU,
GPU
enum DataFormat
NCHW,
NHWC
enum OCRNetDecode
CTC,
Attention
typedef struct
DataFormat input_data_format;
// OCDNetEngine param
char* ocdnet_trt_engine_path;
float ocdnet_binarize_threshold;
float ocdnet_polygon_threshold;
float ocdnet_unclip_ratio;
int ocdnet_max_candidate;
int32_t ocdnet_infer_input_shape[3];
// Rectifier param
bool upsidedown = false;
// OCRNet param:
char* ocrnet_trt_engine_path;
char* ocrnet_dict_file;
int32_t ocrnet_infer_input_shape[3];
OCRNetDecode ocrnet_decode = CTC;
// common param
} nvOCDRParam;
typedef struct
int shape[4];
void* mem_ptr;
Device device_type;
// DataPrecision precision;
// DataFormat data_format;
} nvOCDRInput;
typedef struct
int32_t poly_cnt;
int32_t polys[MAX_PLY_CNT];
int32_t ch_len;
char ch[MAX_CHARACTER_LEN];
float conf;
} nvOCDROutputBlob;
typedef struct
int32_t batch_size;
int32_t text_cnt[MAX_BATCH_SIZE];
nvOCDROutputBlob* text_ptr;
} nvOCDROutputMeta;
nvOCDRp nvOCDR_init(nvOCDRParam param);
nvOCDRStat nvOCDR_inference(nvOCDRInput input, nvOCDROutputMeta* output, nvOCDRp nvocdr_ptr);
nvOCDRStat nvOCDR_high_resolution_inference(nvOCDRInput input, nvOCDROutputMeta* output, nvOCDRp nvocdr_ptr,
float overlap_rate);
void nvOCDR_deinit(nvOCDRp nvocdr_ptr);
ifdef __cplusplus
endif
endif
