**• jetson
**• DeepStream Version 6.1
**• JetPack Version (valid for Jetson only)5.0.1dp
jetpack 5.0.1dp, roughly fresh environment, no complex software installed. the deepstream-test1 graph cannot run successfully
information is as below, please help.
Using winsys: x11
0:00:05.832253162 15228 0xffff44002390 INFO nvinfer gstnvinfer.cpp:646:gst_nvinfer_logger:<nvinfer_bin_nvinfer> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1900> [UID = 1]: deserialized trt engine from :/tmp/ds.deepstream-test1/gxf/sample_models/primary.resnet10.caffemodel_b1_gpu0_int8.engine
INFO: [Implicit Engine Info]: layers num: 3
0 INPUT kFLOAT input_1 3x368x640
1 OUTPUT kFLOAT conv2d_bbox 16x23x40
2 OUTPUT kFLOAT conv2d_cov/Sigmoid 4x23x40
0:00:05.900675080 15228 0xffff44002390 INFO nvinfer gstnvinfer.cpp:646:gst_nvinfer_logger:<nvinfer_bin_nvinfer> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2003> [UID = 1]: Use deserialized engine model: /tmp/ds.deepstream-test1/gxf/sample_models/primary.resnet10.caffemodel_b1_gpu0_int8.engine
nvbufsurface: Failed to create EGLImage.
0:00:05.912543544 15228 0xffff44002390 WARN nvinfer gstnvinfer.cpp:943:gst_nvinfer_start:<nvinfer_bin_nvinfer> error: Failed to set buffer pool to active
2022-06-30 18:02:08.208 ERROR extensions/nvdsbase/nvds_scheduler.cpp@307: Error from /GstPipeline:NvDsScheduler-Pipeline/GstDsNvInferBin:NvDsInferVideo…5080/nv_ds_infer10…2748/GstNvInfer:nvinfer_bin_nvinfer: Failed to set buffer pool to active
2022-06-30 18:02:08.208 ERROR extensions/nvdsbase/nvds_scheduler.cpp@309: Debug info:
/dvs/git/dirty/git-master_linux/deepstream/sdk/src/gst-plugins/gst-nvinfer/gstnvinfer.cpp(943): gst_nvinfer_start (): /GstPipeline:NvDsScheduler-Pipeline/GstDsNvInferBin:NvDsInferVideo…5080/nv_ds_infer10…2748/GstNvInfer:nvinfer_bin_nvinfer
2022-06-30 18:02:08.218 ERROR extensions/nvdsbase/nvds_scheduler.cpp@179: Failed to set GStreamer pipeline to PLAYING
Returned, stopping playback
Deleting pipeline
2022-06-30 18:02:08.224 INFO gxf/gxe/gxe.cpp@320: Deinitializing…
2022-06-30 18:02:08.229 INFO gxf/gxe/gxe.cpp@327: Destroying context
2022-06-30 18:02:08.231 INFO gxf/gxe/gxe.cpp@333: Context destroyed.
End deepstream-test1.yaml
[INFO] Graph installation directory /tmp/ds.deepstream-test1 and manifest /tmp/ds.deepstream-test1/manifest.yaml retained
