Composer open stage full of noise
After I installed the new version of Composer, I found that even when opening a brand-new empty scene, it was full of noise, as shown in the image below. The same issue occurs with my own scene as well. No error message appeared during the operation. Anyone can give some suggestions?
Operating System:
Linux
Kit Version:
108 (Kit App Template)
Kit Template:
USD Composer
GPU Hardware:
L40S
GPU Driver:
Latest: 580
@vic-chen just curious - is your hardware setup working in other kit versions or does this issue pertains only on the latest kit 108.1.0?
That is very likely a driver issue. It must not be compatible with our denoiser.
  1. Please update to very latest GPU driver. If that does not work, try downgrading your drivers to R575. You can see the requirements here Technical Requirements — Omniverse USD Composer
  2. Does it just do this with Kit 108.1, 108.0 ?
