Composer shows RTX loading and wont disapper suddenly
Hi, I was using Composer 2023.2.5 to develop, but one day it shows RTX loading and wont disappear suddenly.
As the picture I’ve attached. However, Isaac Sim can work perfectly.
I’m using Geforce RTX 3060.
Ok thanks for the post. A couple of important points to make:
  1. You are using a really old version of Composer. 2023.2.5, as the name suggests in the old version on Launcher. We not longer use Launcher, or publish new products to it. This workflow is considered legacy. The latest Kit 107.0 is now available for free, without needing any user login, on our GitHub page at GitHub - NVIDIA-Omniverse/kit-app-template: Omniverse Kit App Template
If you are not super familiar with GitHub, you can follow these quick installation instructions.
1. Download "git" from https://git-scm.com/downloads
2. Download "git Large File Storage from https://git-lfs.com/
3. Start a windows command console by using running "cmd" from the Windows Start menu
4. Navigate to the root of c: or d: drive. Example "cd\"
5. Copy and run "git clone https://github.com/NVIDIA-Omniverse/kit-app-template.git"
6. run "cd kit-app-template"
7. run "repo template new"
8. run "repo build"
9. run "repo launch"
HERE is a VIDEO GUIDE as well
  1. The 3060 GPU, whilst able to run basic Composer files, has very little VRAM in its base, 6GB configuration. Do you have the 6GB or the 12GB version?
  2. Finally if you want to “factory reset” this system, just to see if it works, you can go to PREFERENCES > Reset to Default (right at the top corner) and let the program do a complete factory reset.
Thanks for the help, it works!
