Composer : UNAVAILABLE: ipv4:127.0.0.1:50051 / a solution is needed
Hello
I’m working on a windows 10 machine. I have the following problem.
2024-03-01 03:28:38 [Error] [omni.exp.graph.composer.registry_window] details = “failed to connect to all addresses; last error: UNAVAILABLE: ipv4:127.0.0.1:50051: Connection refused”
Do you know how to get rid of this error
Thank you a lot
Olli
The gxf_server must be run to get the composer to work. Application Workflow — DeepStream documentation 6.4 documentation
There is no “gxf_server” for windows. You must have a device Ubuntu 22.04 LTS (x86_64) — DeepStream documentation 6.4 documentation or a device Ubuntu 22.04 LTS (x86_64) — DeepStream documentation 6.4 documentation which has installed Graph Composer package. Then you can run “gxf_server” in the device.
You must configure the Windows composer by setting ip address to the “gxf_server” device with “Edit->Preferences->server” , then your windows Graph Composer can work.
