I ran same command on 2.7.25 and was able to see the live visualization for shoes using Intel RealSense D435 camera. Now, when I run it, I get this error. Could you please help how to fix it? When I visualize it with rviz, the visualized item is grey. I am able to see the feed inside the docker using realsense-viewer.
admin@DOS:/workspaces/isaac_ros-dev/isaac_ros_assets/models$ ros2 launch isaac_ros_examples isaac_ros_examples.launch.py launch_fragments:=realsense_mono_rect,centerpose,centerpose_visualizer model_name:=centerpose_shoe model_repository_paths:=[${ISAAC_ROS_WS}/isaac_ros_assets/models]
[INFO] [launch]: All log files can be found below /home/admin/.ros/log/2025-02-10-13-38-13-419625-DOS-29388
[INFO] [launch]: Default logging verbosity is set to INFO
[INFO] [component_container_mt-1]: process started with pid [29401]
[component_container_mt-1] [INFO] [1739212693.735613082] [isaac_ros_examples.container]: Load Library: /opt/ros/humble/lib/libresize_node.so
[component_container_mt-1] [INFO] [1739212693.749205254] [isaac_ros_examples.container]: Found class: rclcpp_components::NodeFactoryTemplate<nvidia::isaac_ros::image_proc::ResizeNode>
[component_container_mt-1] [INFO] [1739212693.749237422] [isaac_ros_examples.container]: Instantiate class: rclcpp_components::NodeFactoryTemplate<nvidia::isaac_ros::image_proc::ResizeNode>
[component_container_mt-1] [INFO] [1739212695.917159649] [centerpose_encoder.resize_node]: [NitrosNode] Initializing NitrosNode
[component_container_mt-1] [INFO] [1739212695.917324174] [NitrosContext]: [NitrosContext] Loading extension: gxf/lib/std/libgxf_std.so
[component_container_mt-1] [INFO] [1739212695.918121220] [NitrosContext]: [NitrosContext] Loading extension: gxf/lib/libgxf_isaac_gxf_helpers.so
[component_container_mt-1] [INFO] [1739212695.920184320] [NitrosContext]: [NitrosContext] Loading extension: gxf/lib/libgxf_isaac_sight.so
[component_container_mt-1] [INFO] [1739212695.922202224] [NitrosContext]: [NitrosContext] Loading extension: gxf/lib/libgxf_isaac_atlas.so
[component_container_mt-1] 2025-02-10 13:38:15.927 WARN gxf/std/program.cpp@538: No GXF scheduler specified.
[component_container_mt-1] [INFO] [1739212695.927456997] [centerpose_encoder.resize_node]: [ResizeNode] Set output data format to: "nitros_image_rgb8"
[component_container_mt-1] [INFO] [1739212695.927500623] [centerpose_encoder.resize_node]: [NitrosNode] Starting NitrosNode
[component_container_mt-1] [INFO] [1739212695.933532206] [centerpose_encoder.resize_node]: [NitrosNode] Loading extensions
[component_container_mt-1] [INFO] [1739212695.933589496] [centerpose_encoder.resize_node]: [NitrosContext] Loading extension: gxf/lib/multimedia/libgxf_multimedia.so
[component_container_mt-1] [INFO] [1739212695.935319318] [centerpose_encoder.resize_node]: [NitrosContext] Loading extension: gxf/lib/libgxf_isaac_message_compositor.so
[component_container_mt-1] [INFO] [1739212695.935634669] [centerpose_encoder.resize_node]: [NitrosContext] Loading extension: gxf/lib/cuda/libgxf_cuda.so
[component_container_mt-1] [INFO] [1739212695.937118719] [centerpose_encoder.resize_node]: [NitrosContext] Loading extension: gxf/lib/libgxf_isaac_tensorops.so
[component_container_mt-1] [INFO] [1739212695.939234647] [centerpose_encoder.resize_node]: [NitrosNode] Loading graph to the optimizer
[component_container_mt-1] [INFO] [1739212695.941406218] [centerpose_encoder.resize_node]: [NitrosNode] Running optimization
[component_container_mt-1] [INFO] [1739212696.044679950] [centerpose_encoder.resize_node]: [NitrosNode] Obtaining graph IO group info from the optimizer
[component_container_mt-1] [INFO] [1739212696.046598301] [centerpose_encoder.resize_node]: [NitrosPublisherSubscriberGroup] Pinning the component "image_sink/sink" (type="nvidia::isaac_ros::MessageRelay") to use its compatible format only: "nitros_image_rgb8"
[component_container_mt-1] [INFO] [1739212696.051143353] [centerpose_encoder.resize_node]: [NitrosNode] Starting negotiation...
[component_container_mt-1] [INFO] [1739212696.051607809] [isaac_ros_examples.container]: Load Library: /opt/ros/humble/lib/librealsense2_camera.so
[INFO] [launch_ros.actions.load_composable_nodes]: Loaded node '/centerpose_encoder/resize_node' in container '/isaac_ros_examples/container'
[component_container_mt-1] [INFO] [1739212696.149185045] [isaac_ros_examples.container]: Found class: rclcpp_components::NodeFactoryTemplate<realsense2_camera::RealSenseNodeFactory>
[component_container_mt-1] [INFO] [1739212696.149244401] [isaac_ros_examples.container]: Instantiate class: rclcpp_components::NodeFactoryTemplate<realsense2_camera::RealSenseNodeFactory>
[component_container_mt-1] [INFO] [1739212696.162936478] [realsense2_camera]: RealSense ROS v4.51.1
[component_container_mt-1] [INFO] [1739212696.162969420] [realsense2_camera]: Built with LibRealSense v2.55.1
[INFO] [launch_ros.actions.load_composable_nodes]: Loaded node '/realsense2_camera' in container '/isaac_ros_examples/container'
[component_container_mt-1] [INFO] [1739212696.162978549] [realsense2_camera]: Running with LibRealSense v2.55.1
[component_container_mt-1] [INFO] [1739212696.163761316] [isaac_ros_examples.container]: Load Library: /opt/ros/humble/lib/libimage_format_converter_node.so
[component_container_mt-1] [INFO] [1739212696.165803961] [isaac_ros_examples.container]: Found class: rclcpp_components::NodeFactoryTemplate<nvidia::isaac_ros::image_proc::ImageFormatConverterNode>
[component_container_mt-1] [INFO] [1739212696.165827863] [isaac_ros_examples.container]: Instantiate class: rclcpp_components::NodeFactoryTemplate<nvidia::isaac_ros::image_proc::ImageFormatConverterNode>
[component_container_mt-1] [INFO] [1739212696.175663324] [centerpose_encoder.image_format_converter_node]: [NitrosNode] Initializing NitrosNode
[component_container_mt-1] [INFO] [1739212696.175929958] [centerpose_encoder.image_format_converter_node]: [ImageFormatConverterNode] Set output data format to: "nitros_image_rgb8"
[component_container_mt-1] [INFO] [1739212696.175997403] [centerpose_encoder.image_format_converter_node]: [NitrosNode] Starting NitrosNode
[component_container_mt-1] [INFO] [1739212696.207153941] [centerpose_encoder.image_format_converter_node]: [NitrosNode] Loading extensions
[component_container_mt-1] [INFO] [1739212696.209134034] [centerpose_encoder.image_format_converter_node]: [NitrosNode] Loading graph to the optimizer
[component_container_mt-1] [INFO] [1739212696.213703442] [centerpose_encoder.image_format_converter_node]: [NitrosNode] Running optimization
[component_container_mt-1] [INFO] [1739212696.236083091] [realsense2_camera]: Device with serial number 819112070232 was found.
[component_container_mt-1] [INFO] [1739212696.236148670] [realsense2_camera]: Device with physical ID 3-6.1-21 was found.
[component_container_mt-1] [INFO] [1739212696.236154226] [realsense2_camera]: Device with name Intel RealSense D435 was found.
[component_container_mt-1] [INFO] [1739212696.236288030] [realsense2_camera]: Device with port number 3-6.1 was found.
[component_container_mt-1] [INFO] [1739212696.236295352] [realsense2_camera]: Device USB type: 2.1
[component_container_mt-1] [WARN] [1739212696.236300935] [realsense2_camera]: Device 819112070232 is connected using a 2.1 port. Reduced performance is expected.
[component_container_mt-1] [INFO] [1739212696.237418661] [realsense2_camera]: getParameters...
[component_container_mt-1] [INFO] [1739212696.237691951] [realsense2_camera]: JSON file is not provided
[component_container_mt-1] [INFO] [1739212696.237707821] [realsense2_camera]: Device Name: Intel RealSense D435
[component_container_mt-1] [INFO] [1739212696.237713258] [realsense2_camera]: Device Serial No: 819112070232
[component_container_mt-1] [INFO] [1739212696.237717928] [realsense2_camera]: Device physical port: 3-6.1-21
[component_container_mt-1] [INFO] [1739212696.237722526] [realsense2_camera]: Device FW version: 5.16.0.1
[component_container_mt-1] [INFO] [1739212696.237726636] [realsense2_camera]: Device Product ID: 0x0B07
[component_container_mt-1] [INFO] [1739212696.237730378] [realsense2_camera]: Sync Mode: Off
[component_container_mt-1] [INFO] [1739212696.258314492] [centerpose_encoder.image_format_converter_node]: [NitrosNode] Obtaining graph IO group info from the optimizer
[component_container_mt-1] [INFO] [1739212696.263383278] [centerpose_encoder.image_format_converter_node]: [NitrosPublisherSubscriberGroup] Pinning the component "sink/sink" (type="nvidia::isaac_ros::MessageRelay") to use its compatible format only: "nitros_image_rgb8"
[component_container_mt-1] [INFO] [1739212696.264643232] [centerpose_encoder.image_format_converter_node]: [NitrosNode] Starting negotiation...
[component_container_mt-1] [INFO] [1739212696.264970527] [centerpose_encoder.resize_node]: Negotiating
[INFO] [launch_ros.actions.load_composable_nodes]: Loaded node '/centerpose_encoder/image_format_converter_node' in container '/isaac_ros_examples/container'
[component_container_mt-1] [INFO] [1739212696.265025979] [isaac_ros_examples.container]: Load Library: /opt/ros/humble/lib/libtriton_node.so
[component_container_mt-1] [INFO] [1739212696.268721479] [isaac_ros_examples.container]: Found class: rclcpp_components::NodeFactoryTemplate<nvidia::isaac_ros::dnn_inference::TritonNode>
[component_container_mt-1] [INFO] [1739212696.268747913] [isaac_ros_examples.container]: Instantiate class: rclcpp_components::NodeFactoryTemplate<nvidia::isaac_ros::dnn_inference::TritonNode>
[component_container_mt-1] [INFO] [1739212696.270919277] [centerpose_inference]: [NitrosNode] Initializing NitrosNode
[component_container_mt-1] [INFO] [1739212696.271151794] [centerpose_inference]: [TritonNode] Set input data format to: "nitros_tensor_list_nchw_rgb_f32"
[component_container_mt-1] [INFO] [1739212696.271165273] [centerpose_inference]: [TritonNode] Set output data format to: "nitros_tensor_list_nhwc_rgb_f32"
[component_container_mt-1] [INFO] [1739212696.271196114] [centerpose_inference]: [NitrosNode] Starting NitrosNode
[component_container_mt-1] [INFO] [1739212696.274260436] [centerpose_inference]: [NitrosNode] Loading extensions
[component_container_mt-1] [INFO] [1739212696.274324055] [centerpose_inference]: [NitrosContext] Loading extension: gxf/lib/serialization/libgxf_serialization.so
[component_container_mt-1] [INFO] [1739212696.274707311] [centerpose_inference]: [NitrosContext] Loading extension: gxf/lib/libgxf_isaac_triton.so
[component_container_mt-1] [INFO] [1739212696.295497870] [centerpose_inference]: [NitrosNode] Loading graph to the optimizer
[component_container_mt-1] [INFO] [1739212696.296627889] [centerpose_inference]: [NitrosNode] Running optimization
[component_container_mt-1] [INFO] [1739212696.373320260] [centerpose_inference]: [NitrosNode] Obtaining graph IO group info from the optimizer
[component_container_mt-1] [INFO] [1739212696.383614970] [centerpose_inference]: [NitrosPublisherSubscriberGroup] Pinning the component "triton_request/input" (type="nvidia::gxf::DoubleBufferReceiver") to use its compatible format only: "nitros_tensor_list_nchw_rgb_f32"
[component_container_mt-1] [INFO] [1739212697.058363996] [centerpose_encoder.resize_node]: [NitrosNode] Loading application
[component_container_mt-1] [INFO] [1739212697.060443278] [centerpose_encoder.resize_node]: [ResizeNode] postLoadGraphCallback().
[component_container_mt-1] [INFO] [1739212697.060507382] [centerpose_encoder.resize_node]: [NitrosNode] Initializing and running GXF graph
[component_container_mt-1] [INFO] [1739212697.070745005] [centerpose_encoder.resize_node]: [NitrosNode] Node was started
[component_container_mt-1] 10/02 13:38:17,153 WARNING [132291546318400] (messenger-libusb.cpp:42) control_transfer returned error, index: 768, error: Success, number: 0
[component_container_mt-1] [INFO] [1739212697.265383016] [centerpose_encoder.image_format_converter_node]: [NitrosNode] Starting post negotiation setup
[component_container_mt-1] [INFO] [1739212697.265436037] [centerpose_encoder.image_format_converter_node]: [NitrosNode] Getting data format negotiation results
[component_container_mt-1] [INFO] [1739212697.265442955] [centerpose_encoder.image_format_converter_node]: [NitrosPublisher] Use the negotiated data format: "nitros_image_rgb8"
[component_container_mt-1] [INFO] [1739212697.265449446] [centerpose_encoder.image_format_converter_node]: [NitrosSubscriber] Use the negotiated data format: "nitros_image_rgb8"
[component_container_mt-1] [INFO] [1739212697.265558828] [centerpose_encoder.image_format_converter_node]: [NitrosNode] Exporting the final graph based on the negotiation results
[component_container_mt-1] [INFO] [1739212697.273633736] [centerpose_encoder.image_format_converter_node]: [NitrosNode] Wrote the final top level YAML graph to "/tmp/isaac_ros_nitros/graphs/JOPJNHWKZH/JOPJNHWKZH.yaml"
[component_container_mt-1] [INFO] [1739212697.273683326] [centerpose_encoder.image_format_converter_node]: [NitrosNode] Loading application
[component_container_mt-1] [INFO] [1739212697.274444811] [centerpose_encoder.image_format_converter_node]: [ImageFormatConverterNode] postLoadGraphCallback().
[component_container_mt-1] [INFO] [1739212697.274492048] [centerpose_encoder.image_format_converter_node]: [NitrosNode] Initializing and running GXF graph
[component_container_mt-1] [INFO] [1739212697.275361104] [centerpose_encoder.image_format_converter_node]: [NitrosNode] Node was started
[component_container_mt-1] [INFO] [1739212697.387314503] [centerpose_inference]: [NitrosNode] Starting post negotiation setup
[component_container_mt-1] [INFO] [1739212697.387377104] [centerpose_inference]: [NitrosNode] Getting data format negotiation results
[component_container_mt-1] [INFO] [1739212697.387387826] [centerpose_inference]: [NitrosSubscriber] Use the negotiated data format: "nitros_tensor_list_nchw_rgb_f32"
[component_container_mt-1] [INFO] [1739212697.387406067] [centerpose_inference]: [NitrosPublisher] Negotiation ended with no results
[component_container_mt-1] [INFO] [1739212697.387413365] [centerpose_inference]: [NitrosPublisher] Use only the compatible publisher: topic_name="/tensor_sub", data_format="nitros_tensor_list_nhwc_rgb_f32"
[component_container_mt-1] [INFO] [1739212697.387541496] [centerpose_inference]: [NitrosNode] Exporting the final graph based on the negotiation results
[component_container_mt-1] [INFO] [1739212697.399714519] [centerpose_inference]: [NitrosNode] Wrote the final top level YAML graph to "/tmp/isaac_ros_nitros/graphs/ORDCNIZZKN/ORDCNIZZKN.yaml"
[component_container_mt-1] [INFO] [1739212697.399762911] [centerpose_inference]: [NitrosNode] Loading application
[component_container_mt-1] 2025-02-10 13:38:17.400 WARN gxf/std/yaml_file_loader.cpp@1076: Using unregistered parameter 'dummy_rx' in component 'requester'.
[component_container_mt-1] [INFO] [1739212697.401040523] [centerpose_inference]: In TritonNode postLoadGraphCallback().
[component_container_mt-1] [INFO] [1739212697.401129255] [centerpose_inference]: [NitrosNode] Initializing and running GXF graph
[component_container_mt-1] [INFO] [1739212697.436553209] [centerpose_encoder.crop_node]: [NitrosNode] Starting post negotiation setup
[component_container_mt-1] [INFO] [1739212697.436625901] [centerpose_encoder.crop_node]: [NitrosNode] Getting data format negotiation results
[component_container_mt-1] [INFO] [1739212697.436636735] [centerpose_encoder.crop_node]: [NitrosPublisher] Use the negotiated data format: "nitros_image_rgb8"
[component_container_mt-1] [INFO] [1739212697.436647841] [centerpose_encoder.crop_node]: [NitrosPublisher] Negotiation ended with no results
[component_container_mt-1] [INFO] [1739212697.436655865] [centerpose_encoder.crop_node]: [NitrosPublisher] Use only the compatible publisher: topic_name="/centerpose_encoder/crop/camera_info", data_format="nitros_camera_info"
[component_container_mt-1] [INFO] [1739212697.436665467] [centerpose_encoder.crop_node]: [NitrosSubscriber] Use the negotiated data format: "nitros_image_rgb8"
[component_container_mt-1] [INFO] [1739212697.436706550] [centerpose_encoder.crop_node]: [NitrosSubscriber] Use the negotiated data format: "nitros_camera_info"
[component_container_mt-1] [INFO] [1739212697.436856607] [centerpose_encoder.crop_node]: [NitrosNode] Exporting the final graph based on the negotiation results
[component_container_mt-1] [INFO] [1739212697.457844843] [centerpose_decoder_node]: [NitrosNode] Starting post negotiation setup
[component_container_mt-1] [INFO] [1739212697.457909299] [centerpose_decoder_node]: [NitrosNode] Getting data format negotiation results
[component_container_mt-1] [INFO] [1739212697.457915222] [centerpose_decoder_node]: [NitrosPublisher] Use the negotiated data format: "nitros_detection3_d_array"
[component_container_mt-1] [INFO] [1739212697.457923008] [centerpose_decoder_node]: [NitrosSubscriber] Negotiation ended with no results
[component_container_mt-1] [INFO] [1739212697.457927271] [centerpose_decoder_node]: [NitrosSubscriber] Use the compatible subscriber: topic_name="/tensor_sub", data_format="nitros_tensor_list_nchw_rgb_f32"
[component_container_mt-1] [INFO] [1739212697.457933103] [centerpose_decoder_node]: [NitrosSubscriber] Negotiation ended with no results
[component_container_mt-1] [INFO] [1739212697.457936705] [centerpose_decoder_node]: [NitrosSubscriber] Use the compatible subscriber: topic_name="/camera_info_rect", data_format="nitros_camera_info"
[component_container_mt-1] [INFO] [1739212697.458023042] [centerpose_decoder_node]: [NitrosNode] Exporting the final graph based on the negotiation results
[component_container_mt-1] [INFO] [1739212697.460655188] [centerpose_decoder_node]: [NitrosNode] Wrote the final top level YAML graph to "/tmp/isaac_ros_nitros/graphs/ZLPFAWCXOK/ZLPFAWCXOK.yaml"
[component_container_mt-1] [INFO] [1739212697.460707282] [centerpose_decoder_node]: [NitrosNode] Loading application
[component_container_mt-1] WARNING: infer_trtis_server.cpp:1217 NvDsTritonServerInit suggest to set model_control_mode:none. otherwise may cause unknow issues.
[component_container_mt-1] I0210 18:38:17.486437 29401 pinned_memory_manager.cc:277] "Pinned memory pool is created at '0x784fa6000000' with size 268435456"
[component_container_mt-1] [WARN] [1739212697.486886954] [realsense2_camera]:
[component_container_mt-1] I0210 18:38:17.489881 29401 cuda_memory_manager.cc:107] "CUDA memory pool is created on device 0 with size 67108864"
[component_container_mt-1] I0210 18:38:17.497415 29401 server.cc:604]
[component_container_mt-1] +------------------+------+
[component_container_mt-1] | Repository Agent | Path |
[component_container_mt-1] I0210 18:38:17.497446 29401 server.cc:631]
[component_container_mt-1] +---------+------+--------+
[component_container_mt-1] | Backend | Path | Config |
[component_container_mt-1] I0210 18:38:17.497459 29401 server.cc:674]
[component_container_mt-1] +-------+---------+--------+
[component_container_mt-1] | Model | Version | Status |
[component_container_mt-1] [INFO] [1739212697.509113670] [centerpose_encoder.crop_node]: [NitrosNode] Wrote the final top level YAML graph to "/tmp/isaac_ros_nitros/graphs/RHYRWAAAXF/RHYRWAAAXF.yaml"
[component_container_mt-1] [INFO] [1739212697.509158882] [centerpose_encoder.crop_node]: [NitrosNode] Loading application
[component_container_mt-1] I0210 18:38:17.526851 29401 metrics.cc:877] "Collecting metrics for GPU 0: NVIDIA GeForce RTX 3080 Laptop GPU"
[component_container_mt-1] I0210 18:38:17.529872 29401 metrics.cc:770] "Collecting CPU metrics"
[component_container_mt-1] I0210 18:38:17.529954 29401 tritonserver.cc:2598]
[component_container_mt-1] +----------------------------------+-----------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------+
[component_container_mt-1] | Option | Value |
[component_container_mt-1] | server_id | triton |
[component_container_mt-1] | server_version | 2.49.0 |
[component_container_mt-1] | server_extensions | classification sequence model_repository model_repository(unload_dependents) schedule_policy model_configuration system_shared_memory cuda_shared_memory binary_tensor_data parameters statistics trace logging |
[component_container_mt-1] | model_repository_path[0] | /workspaces/isaac_ros-dev/isaac_ros_assets/models |
[component_container_mt-1] | model_control_mode | MODE_EXPLICIT |
[component_container_mt-1] | strict_model_config | 1 |
[component_container_mt-1] | model_config_name | |
[component_container_mt-1] | rate_limit | OFF |
[component_container_mt-1] | pinned_memory_pool_byte_size | 268435456 |
[component_container_mt-1] | cuda_memory_pool_byte_size{0} | 67108864 |
[component_container_mt-1] | min_supported_compute_capability | 6.0 |
[component_container_mt-1] | strict_readiness | 1 |
[component_container_mt-1] | exit_timeout | 30 |
[component_container_mt-1] | cache_enabled | 0 |
[component_container_mt-1] [INFO] [1739212697.530268721] [centerpose_inference]: [NitrosNode] Node was started
[component_container_mt-1] I0210 18:38:17.532135 29401 model_lifecycle.cc:472] "loading: centerpose_shoe:1"
[component_container_mt-1] [INFO] [1739212697.533632105] [centerpose_encoder.crop_node]: [CropNode] postLoadGraphCallback().
[component_container_mt-1] [INFO] [1739212697.533676373] [centerpose_decoder_node]: [NitrosNode] Initializing and running GXF graph
[component_container_mt-1] [INFO] [1739212697.533720044] [centerpose_encoder.crop_node]: [NitrosNode] Initializing and running GXF graph
[component_container_mt-1] [INFO] [1739212697.534157706] [centerpose_decoder_node]: [NitrosNode] Node was started
[component_container_mt-1] [INFO] [1739212697.536461852] [centerpose_encoder.crop_node]: [NitrosNode] Node was started
[component_container_mt-1] I0210 18:38:17.537370 29401 tensorrt.cc:65] "TRITONBACKEND_Initialize: tensorrt"
[component_container_mt-1] I0210 18:38:17.537383 29401 tensorrt.cc:75] "Triton TRITONBACKEND API version: 1.19"
[component_container_mt-1] I0210 18:38:17.537386 29401 tensorrt.cc:81] "'tensorrt' TRITONBACKEND API version: 1.19"
[component_container_mt-1] I0210 18:38:17.537389 29401 tensorrt.cc:105] "backend configuration:\n{\"cmdline\":{\"auto-complete-config\":\"false\",\"backend-directory\":\"/opt/tritonserver/backends\",\"min-compute-capability\":\"6.000000\",\"default-max-batch-size\":\"4\"}}"
[component_container_mt-1] I0210 18:38:17.540469 29401 tensorrt.cc:231] "TRITONBACKEND_ModelInitialize: centerpose_shoe (version 1)"
[component_container_mt-1] I0210 18:38:17.548504 29401 tensorrt.cc:297] "TRITONBACKEND_ModelInstanceInitialize: centerpose_shoe_0 (GPU device 0)"
[component_container_mt-1] [INFO] [1739212697.600741546] [centerpose_visualizer]: [NitrosNode] Starting post negotiation setup
[component_container_mt-1] [INFO] [1739212697.600795814] [centerpose_visualizer]: [NitrosNode] Getting data format negotiation results
[component_container_mt-1] [INFO] [1739212697.600803406] [centerpose_visualizer]: [NitrosPublisher] Negotiation ended with no results
[component_container_mt-1] [INFO] [1739212697.600809674] [centerpose_visualizer]: [NitrosPublisher] Use only the compatible publisher: topic_name="/centerpose/image_visualized", data_format="nitros_image_bgr8"
[component_container_mt-1] [INFO] [1739212697.600815736] [centerpose_visualizer]: [NitrosSubscriber] Negotiation ended with no results
[component_container_mt-1] [INFO] [1739212697.600820081] [centerpose_visualizer]: [NitrosSubscriber] Use the compatible subscriber: topic_name="/image_rect", data_format="nitros_image_bgr8"
[component_container_mt-1] [INFO] [1739212697.600825245] [centerpose_visualizer]: [NitrosSubscriber] Use the negotiated data format: "nitros_detection3_d_array"
[component_container_mt-1] [INFO] [1739212697.600829686] [centerpose_visualizer]: [NitrosSubscriber] Negotiation ended with no results
[component_container_mt-1] [INFO] [1739212697.600833111] [centerpose_visualizer]: [NitrosSubscriber] Use the compatible subscriber: topic_name="/camera_info_rect", data_format="nitros_camera_info"
[component_container_mt-1] [INFO] [1739212697.600921834] [centerpose_visualizer]: [NitrosNode] Exporting the final graph based on the negotiation results
[component_container_mt-1] [INFO] [1739212697.602212595] [centerpose_visualizer]: [NitrosNode] Wrote the final top level YAML graph to "/tmp/isaac_ros_nitros/graphs/ZQYENQMAZE/ZQYENQMAZE.yaml"
[component_container_mt-1] [INFO] [1739212697.602240046] [centerpose_visualizer]: [NitrosNode] Loading application
[component_container_mt-1] [INFO] [1739212697.603061536] [centerpose_visualizer]: [NitrosNode] Initializing and running GXF graph
[component_container_mt-1] [INFO] [1739212697.603487593] [centerpose_visualizer]: [NitrosNode] Node was started
[component_container_mt-1] [INFO] [1739212697.624937185] [centerpose_encoder.interleaved_to_planar_node]: [NitrosNode] Starting post negotiation setup
[component_container_mt-1] [INFO] [1739212697.624988026] [centerpose_encoder.interleaved_to_planar_node]: [NitrosNode] Getting data format negotiation results
[component_container_mt-1] [INFO] [1739212697.624995752] [centerpose_encoder.interleaved_to_planar_node]: [NitrosPublisher] Use the negotiated data format: "nitros_tensor_list_nchw_rgb_f32"
[component_container_mt-1] [INFO] [1739212697.625003554] [centerpose_encoder.interleaved_to_planar_node]: [NitrosSubscriber] Use the negotiated data format: "nitros_tensor_list_nhwc_rgb_f32"
[component_container_mt-1] [INFO] [1739212697.625110365] [centerpose_encoder.interleaved_to_planar_node]: [NitrosNode] Exporting the final graph based on the negotiation results
[component_container_mt-1] [INFO] [1739212697.628383614] [centerpose_encoder.interleaved_to_planar_node]: [NitrosNode] Wrote the final top level YAML graph to "/tmp/isaac_ros_nitros/graphs/GCHRSDFUCE/GCHRSDFUCE.yaml"
[component_container_mt-1] [INFO] [1739212697.628431007] [centerpose_encoder.interleaved_to_planar_node]: [NitrosNode] Loading application
[component_container_mt-1] [INFO] [1739212697.629692589] [centerpose_encoder.interleaved_to_planar_node]: In InterleavedToPlanarNode postLoadGraphCallback().
[component_container_mt-1] [INFO] [1739212697.629750673] [centerpose_encoder.interleaved_to_planar_node]: [NitrosNode] Initializing and running GXF graph
[component_container_mt-1] [INFO] [1739212697.633695677] [centerpose_encoder.interleaved_to_planar_node]: [NitrosNode] Node was started
[component_container_mt-1] [INFO] [1739212697.641069901] [centerpose_encoder.reshape_node]: [NitrosNode] Starting post negotiation setup
[component_container_mt-1] [INFO] [1739212697.641174576] [centerpose_encoder.reshape_node]: [NitrosNode] Getting data format negotiation results
[component_container_mt-1] [INFO] [1739212697.641187430] [centerpose_encoder.reshape_node]: [NitrosPublisher] Use the negotiated data format: "nitros_tensor_list_nchw_rgb_f32"
[component_container_mt-1] [INFO] [1739212697.641210814] [centerpose_encoder.reshape_node]: [NitrosSubscriber] Use the negotiated data format: "nitros_tensor_list_nchw_rgb_f32"
[component_container_mt-1] [INFO] [1739212697.641364253] [centerpose_encoder.reshape_node]: [NitrosNode] Exporting the final graph based on the negotiation results
[component_container_mt-1] [INFO] [1739212697.643968500] [centerpose_encoder.reshape_node]: [NitrosNode] Wrote the final top level YAML graph to "/tmp/isaac_ros_nitros/graphs/LVGBMKXGRM/LVGBMKXGRM.yaml"
[component_container_mt-1] [INFO] [1739212697.644001324] [centerpose_encoder.reshape_node]: [NitrosNode] Loading application
[component_container_mt-1] [INFO] [1739212697.645647803] [centerpose_encoder.reshape_node]: In ReshapeNode postLoadGraphCallback().
[component_container_mt-1] [INFO] [1739212697.645731848] [centerpose_encoder.reshape_node]: [NitrosNode] Initializing and running GXF graph
[component_container_mt-1] [INFO] [1739212697.656862495] [centerpose_encoder.reshape_node]: [NitrosNode] Node was started
[component_container_mt-1] I0210 18:38:17.710883 29401 logging.cc:46] "Loaded engine size: 126 MiB"
[component_container_mt-1] I0210 18:38:17.760320 29401 logging.cc:46] "[MS] Running engine with multi stream info"
[component_container_mt-1] I0210 18:38:17.760345 29401 logging.cc:46] "[MS] Number of aux streams is 6"
[component_container_mt-1] I0210 18:38:17.760350 29401 logging.cc:46] "[MS] Number of total worker streams is 7"
[component_container_mt-1] I0210 18:38:17.760355 29401 logging.cc:46] "[MS] The main stream provided by execute/enqueue calls is the first worker stream"
[component_container_mt-1] I0210 18:38:17.774897 29401 logging.cc:46] "[MemUsageChange] TensorRT-managed allocation in IExecutionContext creation: CPU +0, GPU +246, now: CPU 0, GPU 369 (MiB)"
[component_container_mt-1] I0210 18:38:17.775340 29401 instance_state.cc:186] "Created instance centerpose_shoe_0 on GPU 0 with stream priority 0 and optimization profile default[0];"
[component_container_mt-1] I0210 18:38:17.775530 29401 model_lifecycle.cc:839] "successfully loaded 'centerpose_shoe'"
[component_container_mt-1] INFO: infer_simple_runtime.cpp:71 TrtISBackend id:118 initialized model: centerpose_shoe
[component_container_mt-1] 2025-02-10 13:38:17.864 WARN extensions/triton/inferencers/triton_inferencer_impl.cpp@508: Incomplete inference; response appeared out of order; invalid: index = 3
[component_container_mt-1] 2025-02-10 13:38:17.864 WARN extensions/triton/inferencers/triton_inferencer_impl.cpp@510: Inference appeared out of order
[component_container_mt-1] W0210 18:38:18.531485 29401 metrics.cc:631] "Unable to get power limit for GPU 0. Status:Success, value:0.000000"
[component_container_mt-1] W0210 18:38:19.536522 29401 metrics.cc:631] "Unable to get power limit for GPU 0. Status:Success, value:0.000000"
[component_container_mt-1] W0210 18:38:20.536873 29401 metrics.cc:631] "Unable to get power limit for GPU 0. Status:Success, value:0.000000"
[component_container_mt-1] [ERROR] [1739212775.626219961] [compressed_depth_image_transport]: Compressed Depth Image Transport - Compression requires single-channel 32bit-floating point or 16bit raw depth images (input format is: rgb8).
[component_container_mt-1] [ERROR] [1739212775.692867423] [compressed_depth_image_transport]: Compressed Depth Image Transport - Compression requires single-channel 32bit-floating point or 16bit raw depth images (input format is: rgb8).
[component_container_mt-1] [ERROR] [1739212775.759632533] [compressed_depth_image_transport]: Compressed Depth Image Transport - Compression requires single-channel 32bit-floating point or 16bit raw depth images (input format is: rgb8).
[component_container_mt-1] [ERROR] [1739212775.826358586] [compressed_depth_image_transport]: Compressed Depth Image Transport - Compression requires single-channel 32bit-floating point or 16bit raw depth images (input format is: rgb8).
[component_container_mt-1] [ERROR] [1739212775.892954017] [compressed_depth_image_transport]: Compressed Depth Image Transport - Compression requires single-channel 32bit-floating point or 16bit raw depth images (input format is: rgb8).
[component_container_mt-1] [ERROR] [1739212775.959695004] [compressed_depth_image_transport]: Compressed Depth Image Transport - Compression requires single-channel 32bit-floating point or 16bit raw depth images (input format is: rgb8).
[component_container_mt-1] [ERROR] [1739212776.026363553] [compressed_depth_image_transport]: Compressed Depth Image Transport - Compression requires single-channel 32bit-floating point or 16bit raw depth images (input format is: rgb8).
[component_container_mt-1] [ERROR] [1739212776.093130349] [compressed_depth_image_transport]: Compressed Depth Image Transport - Compression requires single-channel 32bit-floating point or 16bit raw depth images (input format is: rgb8).
[component_container_mt-1] [ERROR] [1739212776.159979521] [compressed_depth_image_transport]: Compressed Depth Image Transport - Compression requires single-channel 32bit-floating point or 16bit raw depth images (input format is: rgb8).
[component_container_mt-1] [ERROR] [1739212776.226647413] [compressed_depth_image_transport]: Compressed Depth Image Transport - Compression requires single-channel 32bit-floating point or 16bit raw depth images (input format is: rgb8).
[component_container_mt-1] [ERROR] [1739212776.293286375] [compressed_depth_image_transport]: Compressed Depth Image Transport - Compression requires single-channel 32bit-floating point or 16bit raw depth images (input format is: rgb8).
[component_container_mt-1] [ERROR] [1739212776.360026547] [compressed_depth_image_transport]: Compressed Depth Image Transport - Compression requires single-channel 32bit-floating point or 16bit raw depth images (input format is: rgb8).
[component_container_mt-1] [ERROR] [1739212776.426745982] [compressed_depth_image_transport]: Compressed Depth Image Transport - Compression requires single-channel 32bit-floating point or 16bit raw depth images (input format is: rgb8).
[component_container_mt-1] [ERROR] [1739212776.493587008] [compressed_depth_image_transport]: Compressed Depth Image Transport - Compression requires single-channel 32bit-floating point or 16bit raw depth images (input format is: rgb8).
[component_container_mt-1] [ERROR] [1739212776.560120372] [compressed_depth_image_transport]: Compressed Depth Image Transport - Compression requires single-channel 32bit-floating point or 16bit raw depth images (input format is: rgb8).
^C[WARNING] [launch]: user interrupted with ctrl-c (SIGINT)
[component_container_mt-1] [INFO] [1739212793.492127184] [rclcpp]: signal_handler(signum=2)
[component_container_mt-1] [INFO] [1739212793.495194642] [centerpose_encoder.reshape_node]: [NitrosNode] Terminating the running application
[component_container_mt-1] [INFO] [1739212793.495206783] [centerpose_encoder.reshape_node]: [NitrosContext] Interrupting GXF...
[component_container_mt-1] [INFO] [1739212793.495366781] [centerpose_encoder.reshape_node]: [NitrosContext] Waiting on GXF...
[component_container_mt-1] [INFO] [1739212793.495375298] [centerpose_encoder.reshape_node]: [NitrosContext] Deinitializing...
[component_container_mt-1] [INFO] [1739212793.495780055] [centerpose_encoder.reshape_node]: [NitrosContext] Destroying context
[component_container_mt-1] [INFO] [1739212793.495869127] [centerpose_encoder.reshape_node]: [NitrosNode] Application termination done
[component_container_mt-1] [INFO] [1739212793.501997551] [centerpose_encoder.interleaved_to_planar_node]: [NitrosNode] Terminating the running application
[component_container_mt-1] [INFO] [1739212793.502004426] [centerpose_encoder.interleaved_to_planar_node]: [NitrosContext] Interrupting GXF...
[component_container_mt-1] [INFO] [1739212793.502146189] [centerpose_encoder.interleaved_to_planar_node]: [NitrosContext] Waiting on GXF...
[component_container_mt-1] [INFO] [1739212793.502149242] [centerpose_encoder.interleaved_to_planar_node]: [NitrosContext] Deinitializing...
[component_container_mt-1] [INFO] [1739212793.502411655] [centerpose_encoder.interleaved_to_planar_node]: [NitrosContext] Destroying context
[component_container_mt-1] [INFO] [1739212793.502495447] [centerpose_encoder.interleaved_to_planar_node]: [NitrosNode] Application termination done
[component_container_mt-1] [INFO] [1739212793.509900329] [centerpose_visualizer]: [NitrosNode] Terminating the running application
[component_container_mt-1] [INFO] [1739212793.509908738] [centerpose_visualizer]: [NitrosContext] Interrupting GXF...
[component_container_mt-1] [INFO] [1739212793.510056412] [centerpose_visualizer]: [NitrosContext] Waiting on GXF...
[component_container_mt-1] [INFO] [1739212793.510059485] [centerpose_visualizer]: [NitrosContext] Deinitializing...
[component_container_mt-1] [INFO] [1739212793.511012787] [centerpose_visualizer]: [NitrosContext] Destroying context
[component_container_mt-1] [INFO] [1739212793.511055780] [centerpose_visualizer]: [NitrosNode] Application termination done
[component_container_mt-1] [INFO] [1739212793.517515921] [centerpose_decoder_node]: [NitrosNode] Terminating the running application
[component_container_mt-1] [INFO] [1739212793.517522450] [centerpose_decoder_node]: [NitrosContext] Interrupting GXF...
[component_container_mt-1] |==================================================================================================================================================================|
[component_container_mt-1] | Job Statistics Report (regular) |
[component_container_mt-1] | Name | Count | Time (Median - 90% - Max) [ms] | Load (%) | Exec(ms) | Variation (Median - 90% - Max) [ns] |
[component_container_mt-1] |------------------------------------------------------------------------------------------------------------------------------------------------------------------|
[component_container_mt-1] | LVGBMKXGRM_sink | 1438 | 0.02 | 0.03 | 0.33 | 0.0 % | 30.7 | 7855 | 14548 | 125375 |
[component_container_mt-1] | LVGBMKXGRM_reshaper | 1438 | 0.07 | 0.09 | 2.31 | 0.1 % | 106.4 | 18551 | 31399 | 415994 |
[component_container_mt-1] | Entity Statistics Report (regular) |
[component_container_mt-1] | Entity Name | Entity State | Count | Time (Median - 90% - Max) [ms] |
[component_container_mt-1] | LVGBMKXGRM_sink | StopPending | 1 | 0.00289 | 0.00289 | 0.00289 |
[component_container_mt-1] | LVGBMKXGRM_sink | Idle | 1438 | 66.82859 | 67.93623 | 90.22056 |
[component_container_mt-1] | LVGBMKXGRM_sink | Ticking | 1438 | 0.01030 | 0.01457 | 0.31507 |
[component_container_mt-1] | LVGBMKXGRM_sink | TickPending | 1438 | 0.00479 | 0.00759 | 0.12732 |
[component_container_mt-1] | LVGBMKXGRM_reshaper | StopPending | 1 | 0.00871 | 0.00871 | 0.00871 |
[component_container_mt-1] | LVGBMKXGRM_reshaper | Idle | 1438 | 66.73471 | 67.88522 | 87.86595 |
[component_container_mt-1] | LVGBMKXGRM_reshaper | Ticking | 1438 | 0.05575 | 0.07723 | 2.28366 |
[component_container_mt-1] | LVGBMKXGRM_reshaper | TickPending | 1438 | 0.00755 | 0.00927 | 0.03082 |
[component_container_mt-1] | GCHRSDFUCE_sink | 1438 | 0.02 | 0.03 | 0.38 | 0.0 % | 35.5 | 10698 | 30111 | 116491 |
[component_container_mt-1] | GCHRSDFUCE_interleaved_to_planar | 1438 | 0.08 | 0.10 | 4.62 | 0.1 % | 126.8 | 19128 | 36651 | 136618 |
[component_container_mt-1] | GCHRSDFUCE_sink | StopPending | 1 | 0.00303 | 0.00303 | 0.00303 |
[component_container_mt-1] | GCHRSDFUCE_sink | Idle | 1438 | 66.75263 | 67.87476 | 88.29906 |
[component_container_mt-1] | GCHRSDFUCE_sink | Ticking | 1438 | 0.01256 | 0.01735 | 0.37503 |
[component_container_mt-1] | GCHRSDFUCE_sink | TickPending | 1438 | 0.00657 | 0.00887 | 0.02385 |
[component_container_mt-1] | GCHRSDFUCE_interleaved_ | StopPending | 1 | 0.00627 | 0.00627 | 0.00627 |
[component_container_mt-1] | GCHRSDFUCE_interleaved_ | Idle | 1438 | 66.72014 | 67.79755 | 88.21439 |
[component_container_mt-1] | GCHRSDFUCE_interleaved_ | Ticking | 1438 | 0.06888 | 0.07848 | 4.58151 |
[component_container_mt-1] | GCHRSDFUCE_interleaved_ | TickPending | 1438 | 0.00875 | 0.01226 | 0.03707 |
^C[WARNING] [launch]: user interrupted with ctrl-c (SIGINT) again, ignoring...
[component_container_mt-1] [INFO] [1739212793.967203117] [rclcpp]: signal_handler(signum=2)
[ERROR] [component_container_mt-1]: process[component_container_mt-1] failed to terminate '5' seconds after receiving 'SIGINT', escalating to 'SIGTERM'
[INFO] [component_container_mt-1]: sending signal 'SIGTERM' to process[component_container_mt-1]
[component_container_mt-1] [INFO] [1739212798.671138397] [rclcpp]: signal_handler(signum=15)
[ERROR] [component_container_mt-1]: process[component_container_mt-1] failed to terminate '10.0' seconds after receiving 'SIGTERM', escalating to 'SIGKILL'
[INFO] [component_container_mt-1]: sending signal 'SIGKILL' to process[component_container_mt-1]
[ERROR] [component_container_mt-1]: process has died [pid 29401, exit code -9, cmd '/opt/ros/humble/lib/rclcpp_components/component_container_mt --ros-args -r __node:=container -r __ns:=/isaac_ros_examples'].
I have attached the whole log in txt file below.
This has been an inconsistent behavior (happens every couple runs).
Also, when it runs correctly, after a few seconds it freezes.
[component_container_mt-1] [INFO] [1739213959.220116271] [centerpose_encoder.reshape_node]: [NitrosNode] Exporting the final graph based on the negotiation results
[component_container_mt-1] [INFO] [1739213959.223254699] [centerpose_encoder.reshape_node]: [NitrosNode] Wrote the final top level YAML graph to "/tmp/isaac_ros_nitros/graphs/AWNWRGXGEZ/AWNWRGXGEZ.yaml"
[component_container_mt-1] [INFO] [1739213959.223312935] [centerpose_encoder.reshape_node]: [NitrosNode] Loading application
[component_container_mt-1] [INFO] [1739213959.224727513] [centerpose_encoder.reshape_node]: In ReshapeNode postLoadGraphCallback().
[component_container_mt-1] [INFO] [1739213959.224798491] [centerpose_encoder.reshape_node]: [NitrosNode] Initializing and running GXF graph
[component_container_mt-1] [INFO] [1739213959.227243103] [centerpose_encoder.reshape_node]: [NitrosNode] Node was started
[component_container_mt-1] I0210 18:59:19.267083 70643 logging.cc:46] "Loaded engine size: 126 MiB"
[component_container_mt-1] I0210 18:59:19.320839 70643 logging.cc:46] "[MS] Running engine with multi stream info"
[component_container_mt-1] I0210 18:59:19.320869 70643 logging.cc:46] "[MS] Number of aux streams is 6"
[component_container_mt-1] I0210 18:59:19.320874 70643 logging.cc:46] "[MS] Number of total worker streams is 7"
[component_container_mt-1] I0210 18:59:19.320879 70643 logging.cc:46] "[MS] The main stream provided by execute/enqueue calls is the first worker stream"
[component_container_mt-1] I0210 18:59:19.338148 70643 logging.cc:46] "[MemUsageChange] TensorRT-managed allocation in IExecutionContext creation: CPU +0, GPU +246, now: CPU 0, GPU 369 (MiB)"
[component_container_mt-1] I0210 18:59:19.338522 70643 instance_state.cc:186] "Created instance centerpose_shoe_0 on GPU 0 with stream priority 0 and optimization profile default[0];"
[component_container_mt-1] I0210 18:59:19.338718 70643 model_lifecycle.cc:839] "successfully loaded 'centerpose_shoe'"
[component_container_mt-1] 2025-02-10 13:59:19.437 WARN extensions/triton/inferencers/triton_inferencer_impl.cpp@508: Incomplete inference; response appeared out of order; invalid: index = 3
[component_container_mt-1] 2025-02-10 13:59:19.437 WARN extensions/triton/inferencers/triton_inferencer_impl.cpp@510: Inference appeared out of order
[component_container_mt-1] W0210 18:59:20.108134 70643 metrics.cc:631] "Unable to get power limit for GPU 0. Status:Success, value:0.000000"
[component_container_mt-1] W0210 18:59:21.115316 70643 metrics.cc:631] "Unable to get power limit for GPU 0. Status:Success, value:0.000000"
[component_container_mt-1] W0210 18:59:22.115675 70643 metrics.cc:631] "Unable to get power limit for GPU 0. Status:Success, value:0.000000"
^^ this is part of the log when it runs correctly, I do see the following two warnings in it:
^^I attached above the screencast that showcases the inference freezing.
