Compute Capability for Geforce GTX 740m
Dear all
I had confused from my GPU cc, when i check the Compute Capability by code using ms visual studio 2013 it gives me that Compute Capability is 3.5,
when i run code with kernel that have recursion it gives me error that till me i must have cc=3.5 or higher
what can i do?
with respect
Compile your code with the appropriate switches to select the cc 3.5 architecture.
In VS 2013 go into project properties, CUDA, and look at the device tab.
thank you a lot
i had opened the device tap, but what i shall do ?
In the CUDA device tab, there should be a Code Generation setting.
You’ll need to change the setting there to compute_35,sm_35
Done !!
thank you
