I wanted to try to use the various tools in compute-sanitizer on my application which, mainly, uses cuBLAS.
I tried to run compute-sanitizer --tool memcheck ./myApp and compute-sanitizer --tool initcheck ./myApp and both commands output the following when I’m not calling cublasSgemm directly:
========= COMPUTE-SANITIZER
//some expected output from my application until one point
========= Error: process didn’t terminate successfully
========= Target application returned an error
========= ERROR SUMMARY: 0 errors
My main.cpp is basically:
int main()
//prepare matrices A,B,C on GPU
GPU::gemm('N', 'N', M, N, K, alpha, A.getDataGPU(), M, B.getDataGPU(), K, beta, C.getDataGPU(), M);
//clean up
and the function GPU::gemm is defined in a gpu_cuda.cpp file:
void GPU::gemm(signed char transa, signed char transb, int m, int n, int k, float alpha, const float *A, int lda, const float *B, int ldb, float beta, float *C, int ldc)
cublasStatus_t status = cublasSgemm(handle_cublas[0], getCublasOperation(transa), getCublasOperation(transb), m, n, k, &alpha, A, lda, B, ldb, &beta, C, ldc);
if (status != CUBLAS_STATUS_SUCCESS)
std::cerr << "cuBlasSgemm error: " << cublasGetStatusName(status) << "\n";
My program runs fine when I don’t use compute-sanitizer.
My program runs fine with compute-sanitizer if I replace the GPU::gemm call with:
cublasSgemm(GPU::handle_cublas[0], CUBLAS_OP_N, CUBLAS_OP_N, M, N, K, &alpha, A.getDataGPU(), M, B.getDataGPU(), K, &beta, C.getDataGPU(), M);
Both gpu_cuda.cpp and main.cpp are compiled with g++ so I don’t understand the problem.
I’m using CUDA toolkit 12.6 on Ubuntu 24.04:
| NVIDIA-SMI 560.35.03 Driver Version: 560.35.03 CUDA Version: 12.6 |
| GPU Name Persistence-M | Bus-Id Disp.A | Volatile Uncorr. ECC |
| | | MIG M. |
| 0 NVIDIA GeForce RTX 4070 ... Off | 00000000:01:00.0 Off | N/A |
| N/A 38C P3 11W / 35W | 8MiB / 8188MiB | 0% Default |
| | | N/A |
which compute-sanitizer
/usr/local/cuda-12.6/bin/compute-sanitizer
ldd myApp
libcudart.so.12 => /usr/local/cuda/targets/x86_64-linux/lib/libcudart.so.12 (0x00007643c8400000)
libcusolver.so.11 => /usr/local/cuda/targets/x86_64-linux/lib/libcusolver.so.11 (0x00007643c0a00000)
libcublas.so.12 => /usr/local/cuda/targets/x86_64-linux/lib/libcublas.so.12 (0x00007643ba200000)
libcusparse.so.12 => /usr/local/cuda/targets/x86_64-linux/lib/libcusparse.so.12 (0x00007643a8600000)
Thanks for the help!
