Compute the corners for an array of prims not a prim in Omniverse Code Script Editor
I wrote the following code which computes the corners for a single prim.
How can I pass an array of prims to it and compute the corners? I need to do this in Omniverse Code Script Editor not Isaac Sim.
import omni.usd
from pxr import Usd, UsdGeom, Gf
#from omni.isaac.core.utils.stage import get_current_stage, open_stage
# import omni.isaac.core.utils.bounds as bounds_utils
# import omni.isaac.core.utils.prims as prims_utils
import numpy as np
ENV_URL ="omniverse://localhost/NVIDIA/Assets/Isaac/2022.2.0/Isaac/Samples/Replicator/Stage/full_warehouse_worker_and_anim_cameras.usd"
#open_stage(ENV_URL)
#result, error = omni.usd.get_context().open_stage(ENV_URL, load_set=omni.usd.UsdContextInitialLoadSet.LOAD_NONE)
omni.usd.get_context().open_stage(ENV_URL)
#stage = get_current_stage()
#floor_prims = [x.GetPath() for x in stage.Traverse() if "SM_floor" in x.GetName() and prims_utils.get_prim_type_name(x.GetPath()) == "Xform"]
floor_prims_paths = [x.GetPath() for x in stage.Traverse() if "SM_floor" in x.GetName() ]
print(floor_prims_paths)
print('dir floor_prims: ', dir(floor_prims_paths))
print('type(floor_prims[0]): ', type(floor_prims_paths[0]))
floor_prims = []
for floor_prim_path in floor_prims_paths:
    floor_prims.append(omni.usd.get_prim_at_path(floor_prim_path))
#bb_cache = bounds_utils.create_bbox_cache()
#combined_range_arr = bounds_utils.compute_combined_aabb(bb_cache, prim_paths=floor_prims)
#min_x, min_y, min_z, max_x, max_y, max_z = combined_range_arr
# bbox = omni.usd.get_context().compute_path_world_bounding_box(floor_prims[0])
# min_x, min_y, min_z, max_x, max_y, max_z = bbox
# print("bbox is: ", bbox)
def compute_bbox_with_cache(cache: UsdGeom.BBoxCache, prim: Usd.Prim) -> Gf.Range3d:
    Compute Bounding Box using ComputeWorldBound at UsdGeom.BBoxCache. More efficient if used multiple times.
    See https://graphics.pixar.com/usd/dev/api/class_usd_geom_b_box_cache.html
    Args:
        cache: A cached, i.e. `UsdGeom.BBoxCache(Usd.TimeCode.Default(), ['default', 'render'])`
        prim: A prim to compute the bounding box.
    Returns:
        A range (i.e. bounding box), see more at: https://graphics.pixar.com/usd/release/api/class_gf_range3d.html
    bound = cache.ComputeWorldBound(prim)
    bound_range = bound.ComputeAlignedBox()
    return bound_range
print('floor_prims: ', floor_prims)
print(type(floor_prims[0]))
bbcache = UsdGeom.BBoxCache(Usd.TimeCode.Default(), ["default", "render"])
print('bbache is: ', bbcache)
bb = compute_bbox_with_cache(bbcache, floor_prims[0])
print(bb)
print(type(bb))
print(bb.GetMax())
print(bb.GetMin())
print(dir(bb))
print(bb.GetCorner)
Also could you please verify if the way I have setup bbcash is correct? I am new to USD API.
