I am attempting to compile radixsort.cu which is source that comes packaged with the SDK 3.2
My linker is set to link against cudpp32.lib and cudart.lib
However, the linker cannot find the function computeNumCTAs() nor getNumCTAs()
I know these are part of something to do with CUDPP. Where are these functions defined?
1>Linking…
1>radixsort.cu.obj : error LNK2001: unresolved external symbol “void __cdecl nvRadixSort::computeNumCTAs(void *,int,bool)” (?computeNumCTAs@nvRadixSort@@YAXPAXH_N @Z)
1>radixsort.cu.obj : error LNK2001: unresolved external symbol “int __cdecl nvRadixSort::getNumCTAs(void *)” (?getNumCTAs@nvRadixSort@@YAHPAX @Z)
brano
April 12, 2011, 12:47pm
2
1>Linking…
Hi!
If you open radixsort project, you will find a file named “radixsort.cpp”. This file contains the computeNumCTAs and getNumCTAs.
Thank I too had the same problem. It is now solved .
